5
I have only ever had ONE person say that they had issues with the upgraded header tank setup. IIRC you are running the MRS setup? If so, did you run the engine thru a couple of heat cycles to purge the air? Did you manually purge the air from the radiator? I can't remember, are you still running the front tank as well?
