Has anyone had problems with the driveline bolts to 2016 IRS, i have some play?
Did not find pulley for new alternator so i welded up clutched pulley.toms 33005.JPGtoms 33003.JPG
Put in some time and got all steering joints close to 30 degrees.toms 33006.JPGtoms 33007.JPGtoms 33008.JPG
And did not like the the end of steering rack shaft, so cut off the end and ground flat place for set screw.toms 33002.JPGtoms 33000.JPG
All steering shaft parts have drilled part holes for set screws.toms 33000.JPG
Did not want to buy wheels and tires till i have body and fenders on. With all on and set i can measure for front and back spacing and tire size. So i put this together.IMG_6963.JPGIMG_6965.JPGIMG_6967.JPG
Body on and bolted. Now on to the hood scoop!DPP_330001.JPGDPP_330002.JPGDPP_330003.JPG
Felt like backing up, but needed to take apart to move forward. Have to undo a lot of parts to get engine out of the way. Did some fiberglass work, mixed up to much and more hardenerIMG_6981.JPGIMG_6995.JPGIMG_7001.JPGIMG_7003.JPG than needed , but it is on the cold side.
First time with foam, yes would have been better to mask first. Did mask after first overflow. IMG_7010.JPGIMG_7012.JPGIMG_7013.JPGIMG_7015.JPGIMG_7016.JPGIMG_7018.JPG
Looks like a cool car in the works. Keep those pictures coming.
The hood was out to far at back, so cut and glassed. Working on form for scoop, will probably glass ofer this.IMG_7019.JPGIMG_7021.JPGIMG_7022.JPGIMG_7023.JPGIMG_7024.JPGIMG_7039.JPGIMG_7042.JPGIMG_7044.JPG
Thinking about putting a DOM tube from middle of roll bar over and down to middle of dash. Will put to firewall frame with bolt together at dash .
How much bolt at dash?
What do you think about this?
Doors work and latch, top of DS door built up. Hood and side panels fit. Doors, hood and side panels good ruff gaped. Working on top!IMG_7063.JPGIMG_7066.JPG
Tom, when aligning the grill, hood, and side panels, did you use the nose cone or hood to set the initial rake of the grill? I am at that stage and trying to figure out how much I should trim vs adjust the grill. Just looking for your advice/thoughts.
I put the grill group ( with a Mike Everson fan shroud ) together and put it on car. There is not much room for adjustment, then fit sides and hood to that. The back bottom of side panel is set so off that. Then Hood sides need to be cut (on mine i cut both sides the same then had to build up the left side). Work on all of them a little at a time( it is easier to cut more times than put back on). I have not done the cone yet, but will cut it in two to fit. Hope this helps!
I have AC so the condenser moves the hole group closer to shocks.
Working on getting the body and top ready for permanent attachment. IMG_7071.JPGIMG_7072.JPGIMG_7074.JPGIMG_7075.JPGIMG_7079.JPG
Will put two pound foam in top, little at a time! Hope holes are big enough to let any extra foam out.
I am going to bolt, glue and then fiberglass the top on. I do things a little different some times, so if anyone has comments let them come.
I plan to attach my coupe top permanent also but haven't a clue how I'm going to do that yet. Hard to see in the photo but what adhesive are you using to "glue" the top on? Also, why the foam and where exactly are you putting it?
Hi Naz
The local paint and body supply store said use MAXIM - multi panel by evercoat. It has 40 to 50 min working time, so i will get my son to help move and bolt top on with glue on. I am using all evercoat products up to main paint.
The foam 2 lb, 2 part. I am putting it in the space between the two sides of top for insulation both heat and noise. Need to be very careful because it gets 30 times bigger. i have very little experience with this so only little at a time.
Thanks 1932, I'll be interested in how this works for you. I'm a long ways from doing mine.
Thanks, watching the foam use and attaching the roof with interest!
I do not know how people work on these cars with the tin work on, i do not bend very good!
I want to get all the panels and parts that bolt to body on so i can work on hood, trunk, doors fit. After the top will go back to side panels, will post pics of my idea on that with no bolts showing.
Came out pretty good.
OK ! What are you doing with the window openings, as in beveling- rounding or how to make look good from inside??
Well i went and cut out all the extra body in the windows, front and back so i use all the window glass!
Other cut i want to do is work out the side so that the window seal goes up to the body.IMG_7105.JPGIMG_7106.JPGIMG_7104.JPGIMG_7099.JPGIMG_7096.JPG
With all that glass you'll need to add a sun visor!! Looks great Tom.
The door window lip is to wide for the window seal that came with kit!IMG_7111.JPGIMG_7116.JPG
Any ideas on side window seal? I will look for seal that fits wider lip, or as last may need glue
Mcmaster-Carr
weather stripping
bulb seal
looks like something should work and for trunk to!
Or not!
The top is on and will not be off anymore!IMG_7122.JPGIMG_7123.JPGIMG_7124.JPG
And bolts
Sanded panel adhesive with 40 grit, then put three layers of fiberglass on that. IMG_7131.JPGIMG_7133.JPGIMG_7134.JPGIMG_7136.JPGIMG_7137.JPGIMG_7146.JPGIMG_7154.JPG
Wow! you sure are doing a lot of body work. Look fwd to seeing how it all works out
Work in progress
Did this to side panels - on back at mid panel it stuck out and at front mid panel it needed to come out.
Hood is good, work on hinges and pins. The nose cone was hard to fit, cut & grind, will do some glass work and bolt on. Had to put finder up and see how it looked-good!IMG_7195.JPGIMG_7200.JPGIMG_7201.JPGIMG_7205.JPGIMG_7206.JPGIMG_7211.JPG
What length did you cut your drive shaft to? About to do the same to my build.
I moved the engine in my build so drive shaft would not be the same.
Drive shaft- midcap to midcap 25 3/8
I hope everyone has as much fun with the hood!IMG_7274.JPGIMG_7275.JPGIMG_7279.JPGIMG_7280.JPGIMG_7288.JPGIMG_7289.JPGIMG_7290.JPGIMG_7294.JPG
Used 1/4 inch stainless bolts for the pins, and moved strut down one inch.
Fenders from Dan and they fit over the stile line at bottom so are same as fram. but need to make a half round to go in side of bottom stile line for back up.
Had to add 1 1/4 to ps board to get front to come out right.IMG_7301.JPGIMG_7302.JPG
Will do bottom next.
Im losing sleep because I think the FF33 is best looking car but non permanent roof worries me.
Do i buy a FF33 or a traditional 33/34 roller.
I want it to look right. I know I can build car, my body guy says permanent roof mounting is no trouble..Please keep pics and info
coming.
What are you gonna do about waterfall.and upholstery. Im thinking maybe modifying waterfall to match inside door look and having upholstery shop do iy up and also upholster a headliner too..Are you gonna run wipers.
I think I could use late jeep wiper set up..Lol wipers can b done even with ac and heat.. its top that worries me.
So keep info coming ,,thanks .
