Results 1 to 5 of 5
Thread: Tail lights wire routing
    I can't seem to find any pictures showing routing of the wire harness to the tail lights. I'm concerned about putting s large over hung moment on the connectors since I can't think of a decent way to support the harness weight. I don't like the idea of having two feet of wire mass supported vertically from the electrical connector to rise from the transmission frame rail section.
    I'm thinking of tieing it to the side sail flange and bumper flange where the deck lid sits. Can you please post some pictures how you have these wires routed?
    Image of my engine bay.
    Aug 2012
    Long Island
    run them underneath the lip of the quarters and rear section and feed the the lights from the top.
    attach to the metal of the cross brace and the little metal triangles that will hold your rear hood pins.
    Leesburg, VA
    Anchor the wiring to the fiberglass with TC105 wire tie-downs and loctite adhesive:
    http://thefactoryfiveforum.com/showt...-tips!-Sharing
    Here's how I did mine:
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    I did it the exact same way longislandwrx and STiPWRD mentioned. Looks great.
    Perfect, thanks
