Results 1 to 4 of 4
Thread: Tremec 3650 fluid type ??
    Senior Member 3yearplan's Avatar
    Dearborn Heights, MI
    For those that have this transmission or just have some knowledge to share any help would be appreciated. This question refers to a 2004 trans. What fluid is recommended ? The forums (Mustang) are all over the place. Even Tremec themselves are a bit misleading. Regular Dex 3/ Merc. to Mobil 1 full synthetic to GM/Pennzoil Synchromesh. I've read so much about each, pros and cons, blah, blah, blah. What do the people on HERE know?
    Thanks in advance, Mike.
    Mark IV 7923 arrived 11-14-12
    DOHC 4.6L, Tremec 3650, 3 Link 8.8 w/3.73
    Grand Rapids, MI
    I like and use Red Line MTL. Have used Dexron and Royal Purple SyncroMesh. I've never noticed huge differences. Lots of opinions & options. Have also heard that running a little (maybe a third or half qt) low makes shifting easier or faster. My trans is a 2004 TKO-600 rebuilt by Liberty Gears with all of their upgrades.
    Jim
    I have always used the GM Synchromesh in my TKO500. But 2nd gear synchro is getting a little weak so a couple of months ago I used 2 qts of Pennsoil Synchromesh and the last 3/4 qt 75-80 synthetic trans oil. This helped the 1-2 shift.
    Thanks guys. It's a 78,000 mile trans so I'm not too worried about it, but was just wondering what to stay away from.
