Are there any owners of the 33 Hot Rod ( prefer with a hard top ) in the DFW are that I can try to fit into?
try looking at http://thefactoryfiveforum.com/showt...ers-Google-Map
That doesn't list their forum user names, though.
Oh, whoops, you're right! That doesn't seem very useful![]()
A question for http://thefactoryfiveforum.com/member.php?710-geoffav then - perhaps he can explain how to use it..
I found a long-winded way to do it.. search that thread for the name you find on the map and you'll see who posted it..
Look up WRP, he's local, pretty near you if I remember right.
Let me know if you touch base, I'd like to go see his car too.
FFR 7123 tilt front, Levy 5link/wilwoods/LCA's, webers.
SL-C, LS3 525, Mendeola SDR5,
I'm building in Haslet, but only a week in. Not sure there's much to see at this point!
I know Haslet, my mother used to live in that area. Did you opt for the hardtop?
here's a link to WRP's build thread: http://thefactoryfiveforum.com/showt...it-075-Restart
just click on his user name and send him a private message.
Nevin, AKA H. R. Lucky
33 Hot Rod sn 524 build started 3/18/2013, First Start-5/09/2015, Go Cart-6/01/2015
5.0 Coyote engine, 9in. Ford rear, 4 Link, Wilwood 12in. front brakes
AC, power steering, FFR 17/18in. Hot Rod wheels
I have a 33 Ford roadster. Your head isn't going to be the problem, if it is your feet won't fit. Sent you a PM/replied.
My feet are always a problemReplied to your PM
Yes, I did. Just now installing rear brakes...http://thefactoryfiveforum.com/showt...Mobile-1-Build
So Mick_D what part of DFW are you in?
Tim
I'm in North Carrollton, just between The Colony and Lewisville, south of 121. Where are you?
I live in West Frisco and am just north of The Colony. My stage 1 Hot Rod gets delivered next month, you are welcome to drop by and check it all out once it gets here.
Tim
