Thread: Wipers in PA
    Bourne-Cape Cod, MA
    Wipers in PA
    Are windshield,wipers required on a roadster(mkiv) in PA?
    FFinisher/AKA RE63
    Pittsburgh, PA
    Yes, see section 4524(d) of the Pennsylvania Motor Vehicle Code:
    (d) Windshield wiper systems. -- The windshield on every motor vehicle other than a motorcycle or special mobile equipment shall be equipped with a wiper system capable of clearing rain, snow or other moisture from the windshield, and so constructed as to be controlled or operated by the driver of the vehicle.
    Senior Member RickP's Avatar
    Boyertown, PA
    I'm getting my roadster safety inspected at a place in Pottstown. Yes, you need wipers but it can be a windshield clip on and must be operated via a switch. I found a solution on some hot rod site where it clips to the windshield frame and will plug into a power port. Once I get past inspection, it will get tossed in the trunk never to be used again.
    Bourne-Cape Cod, MA
    Quote Originally Posted by RickP View Post
    Can you get me a part number and vendor .? So I can check it,out?
    FFinisher/AKA RE63
    Boyertown, PA
    Quote Originally Posted by FFinisher View Post
    this what I was thinking.....
    http://www.speedwaymotors.com/Quick-...otor,5513.html
    part# 1932-36. Pricey sucker but would get the job done. If you see a better option out there, please share.
    May 2013
    Harrisburg, PA
    PA requires the following to pass enhanced inspection:
    - wipers - Subchapter E 175.71
    - backup light - Subchapter E 175.66 (j)
    - Sidepipe heatshields - Subchapter E 175.75 (b) (4)
    - Hazard Lamps - Subchapter K, 175.205
    - Hood scoop or projections <2" tall - Subchapter K 175.206 (c)
    - bumpers - Subchapter K 175.209 (b)
    - scrub line - 175.209 (c)
    Documents to review for titling/registering in PA:
    Special Construction Fact Sheet
    Subchapter K
    Pub 45 Inspection Requirements
    ~ Bruce
    MK4 #8189
    400hp 351w, TKO600, 3.27 3-link
