Oil Pan hanging below frame
I have the standard ford 351w front sump chrome oil pan and it hangs below the frame. I just purchased the Aviaid oil pan #15555363 sbfw Daytona coupe pan, it comes with the pickup. I also got the dip stick kit part #15959446. Has anyone else used this pan and am I correct by using this part for replacement of the standard pan to get up under the frame rails. Motor is 351w based motor stroked to 408.
I had a custom canton pan made to avoid that problem.
