Results 1 to 3 of 3
Thread: FS - Mk3.1 Front Upper Control Arms
    Out Drivin' Gumball's Avatar
    Blackberry Township, IL
    These were assembled, greased, and installed on my roller, but then removed before go-kart stage, so no road use. Have the grooved shaft for better grease distribution.
    Comes as a set of two and includes the longer adjustable steel sleeves for more caster / camber.
    $100 for the full set, plus buyer pays shipping.
    Later,
    Mk3.1 #7074
    Here's a deal - how about $50 each and I'll split the set if you only need one to replace the one you didn't quite grease enough.... or the older one that doesn't have the grease grooves like these.
    Buyer pays shipping, though, still.
    Later,
    Mk3.1 #7074
    Found a new home with Mark.
    Thanks!!!!
    Later,
    Mk3.1 #7074
