Thread: Rear End Vent
    Senior Member JOP33's Avatar
    Haslet, Texas
    Rear End Vent
    How are most of you handling the small vent on the 8.8 rear ends? Mine just came with a hose barb & no info
    Senior Member Lowrod's Avatar
    Nov 2015
    Mount Olive AL.
    That's the same vent my 8.8 is equipped with!
    Houston, TX
    Anyone with the IRS setup have a vent in theirs? Mine didn't come with one and have been trying to track one down.
    Quote Originally Posted by RoadRacer View Post
    Nice one Roadracer
    Ohio
    Got my fitting and tube from my Ford dealer. Tube had to be straightened in some places and bent in others for a good fit. A heat gun works very well with the tube. Easy to bend or straighten. Just take your time.
    JRL16
    Haslet, Texas
    Quote Originally Posted by JRL16 View Post
    Happen to have a pic or part #?
    I used a glass filter with the hose connection removed from one end and frame mounted.
    Colorado Springs
    Quote Originally Posted by DarthTedious View Post
    No longer available from Ford.
    The hole is about the same size as 3/8 Tube. I clamped a hose around a short piece of tubing, and then epoxied the tubing into the hole in the differential. That was about 2 years ago. It's only a track car, so it doesn't get a lot of miles. But it seems to be holding well.
    .boB "Iron Man"
    www.RacingTheExocet.com
