Results 1 to 12 of 12
Thread: Rear End Gear Oil Fill
    Apr 2014
    Memphis, TN
    I can't find any instructions that came with my rear end from F5R, but I know I need to fill it up with gear oil. Do I need to get a new gasket when I add the oil or can I reuse what is on there now. How much do I torque the bolts on the differential cover?
    Ryan
    33 Hot Rod
    Quote Originally Posted by rychi1 View Post
    No need to remove the rear cover. There is a fill port on the forward passenger side of the housing. If you do pull the cover, the gasket will likely be trash. Just clean off the material from both the housing and cover and use RTV to make a leak-free gasket.
    Edit: I'm assuming you have a Moser 8.8 if you bought it from FF.
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    Prairieville, Louisiana
    Do you have factory style limited slip? If so, you need a bottle of friction modifier also.
    As papa said, use the plug. It's the only way to measure. Set it up with the close to correct pinion angle, pull plug and fill it. Takes about 2 3/4 bottle if I remember right. A piece of tubing helps. Put the modifier in first then the oil. Full till it's at the threads of the plug. A little coming out is ok. Clean up mess and put in plug. Then open another beer.
    '33 Hot Rod
    MK4 Roadster
    Apr 2014
    Memphis, TN
    Yes Moser 8.8 from FF. The only thing is see that might be a fill hole has a square plug. I am guessing that must be it.
    Ryan
    33 Hot Rod
    Should look like this. 1/2" drive square should plug right into it. It's just a regular pipe thread plug. Teflon tape or hoop it when you reinstall it.
    '33 Hot Rod
    MK4 Roadster
    Apr 2014
    Memphis, TN
    Yes that is it. Thanks for the help.
    Ryan
    33 Hot Rod
    Can you overfill a rear? Just curious since I've no experience with solid rears and I simply added the documented amount (that I found online, don't remember what it was now), while the cover was off and facing up. I didn't use the plug at all..
    You can overfill it and cause the oil to froth, as I understand. Would also cause problems at the end seals and maybe pinion seal. But if you added the documented amount, it should be fine.
    '33 Hot Rod
    MK4 Roadster
    Apr 2014
    Memphis, TN
    I used a 3/8 ratched extension and took out the plug added the 1.875 quarts of gear oil plus the 4oz friction modifier as described in the manual. Put some teflon tape on the plug and screwed it back in. Pretty easy and quick.
    Ryan
    33 Hot Rod
    wallace18's Avatar
    Trenton, Florida
    The Moser rear takes 3 liters of synthetic 75W90 gear lube. No friction modifier. It should have come with instructions. I just installed one in the 33 I am building.
    True for FFR500XXX-3 - TSD500 3-Link Rear End. http://www.moserengineering.com/medi...5/f/i/file.png
    The setup I received is the FFR88355-3 - 8.8. It has the Ford Trac-Loc with clutches and requires a friction modifier. https://www.carid.com/images/ford-pe...4204-f318c.jpg
    I'm definitely not an expert on this subject, but just finished researching this topic for myself with some help from the guys on the Roadster Forum: http://thefactoryfiveforum.com/showt...r-End-Gear-Oil
    I also received this from Moser:
    If you put a full three quarts in the rear it will most likely be overfilled and will make the rear end build pressure. I would stick to what factory five said around the 2 quart range.
    Brian Miles
    Technician/Purchasing Assistant
    102 Performance Drive
    Portland, Indiana 47371
    260 . 726 . 6689
    260 . 726 . 4159 fax
    Legal: 1/30/2020
    I see only the one plug - assuming to fill (even though the manual said to remove rear cover). While filling, I see a few mentioned the correct PINION angle - what is that - wouldn't I just keep the drive shaft connector parallel with the ground? Also where can I find the friction modifier - is this a common AutoZone type product?
    I did question the same on another post, but found this while searching.
    Thanks to all for educating me every time!
    Walter
