Been doing a little work on installing a heater. We don't need A/C here....
Bought the Vintage Air Gen II unit from Summit.
Basically just a heat exchanger, in a nice neat package.... 10 x 10 x 6 in. Comes with three control knobs for temp, heater/defog switch ( 3 position), and 3 blower speeds. The kit includes the hoses and defroster vents.
There is quite a bit of room below the top dash surface and I wanted to mount it as high as possible to allow the air to feed both passenger and driver side when on heat mode. I made a couple brackets from the back and mounted it as high as I could.
I didn't like the switch mounting bracket the sent, so I made my own and transferred the switches and the function decals.
Then integrated into the console.
I'm going to run the car for a while first, then hook up the heater once everything else is working well.
Fits in great......
edit...damn the pics rotated again!!
