Results 1 to 9 of 9
Thread: toploader trans
    Jul 2014
    colorado springs co.
    toploader trans
    Has anyone installed a toploader behind an FE, if so did it need any special work to get it to work?
    Maricopa AZ
    No real work except shift handle location. You will be much happier with a 5 speed.
    Quote Originally Posted by Gordon Levy View Post
    Gordon Is 100% Correct Regarding Your Long Term Happiness!
    The Toploader just won't be any fun if you do any driving at interstate speeds.
    Jul 2014
    for drive shaft can I use the drive shaft that ff5 sells? trans is about same length, spline is 28, so i'm assuming it will work.
    Maricopa AZ
    Depending on what tail housing and output shaft you have makes a difference. Once you have it together and do some measuring and I can have one made for you for $300
    Jul 2014
    Thanks Gordon, I have the transmission from a 66 fairline from a 390 car. Short tail 28 spline from what I found researching. I will hit you up as soon as I get it in. Will drive shaft come with spline for top loader and for 8.8 rear mount?
    Maricopa AZ
    Yes it will
    May 2022
    Quote Originally Posted by feadam View Post
    I know your post is several years old, but did you end up installing the Top loader into the roadster? I've got a rebuilt Top loader that I plan to use behind a BBF 429 in my MKIV. My concern is clearance for the shift linkage and also shifter location.
    Senior Member Rdone585's Avatar
    Jul 2020
    Near Milwaukee, WI
    If you're considering a 429 Boss engine, I'm not certain it will fit. If I remember correctly they have monster sized heads. Has anyone put one of these in a FFR before?
    MkII: 408 Dart block dry sump, 750cfm carb, G-Force T-5, 8.8 rear with 3.55 gears, 3-link, Kirkey seats, black ceramic coated twister mufflers with shields and adjustable turn down tips, passenger roll bar, front and rear roll bars. 2020 GT500 Magnetic metallic, with white and lime green stripes.
