yes you are.
there are 3 places to mount the clutch cable
the donor pedal box location that you have.
The very left of the pedal box as shown in 2nd post photo this was done to use the wilwood pedals.
the 3rd is FFR has moved it in from the 2nd location by approx. 3" to work better on the wilwood pedals
the factory cable comes with a large rubber bushing on it
you need that to mount the cable in the donor pedal box location which you have.
of coarse then there are the hydraulic clutch choices of which there are several designs and choices there also.
