Thanks Bill. Glad you are working on yours again
With all the little steps your taking in this build I hope your keeping up with your 13-2 write-ups.
oh! Now that's interesting..... gives me an idea.....
Logbook in the car with all type of documentation.... registration ; build sheet ; dyno sheet; maybe a generic 2408-12 and -13; -18 inspections for oil change....build pictures....
thanks!
just got my kit on Monday, didn't get all the parts and found some missing. but finally got to get some work done today, getting what I can done. just curious what you did for your gas pedal. the stock pedal you get with the control pack will not fit in the foot box. did you have to modify it to make it fit or use a different pedal?
You have to trim the pedal per the instructions...assuming you are using the coyote pedal? There is a set of coyote install instruction you need if you don't have it already.
yea im using the coyote pedal, I got no instructions in the kit for anything.
measure twice cut once!
and to be clear - I started cutting a little bit of a time and cut as little as possible
ok thank you, yea always a good idea. I found those instructions on the website. btw your kit is looking very nice, all the pictures are cool
I did not cut the arm of the pedal yet... seems ok to leave full length and isn't too sensitive.
yea I was trying not to cut the arm as well, mocking up my seat in place right now to see how much room I can get with the seat im gunna run.
Getting closer!
Now for the fun part. Bondo dust in the summer-yea!
I want to put out a huge HUGE THANKS to Wayne.... who put the killer tune on the HAWK COUPE..... I think this should do quite well!!! I can't thank you enough Wayne.... He kept sending me texts with more and more power.....so VERY COOL!
video will follow... this is right at about 10 psi....A little more than we were shooting for.... but....all good!
That'll be fun!
I've been following, quietly.
Impressive performance and build.
Jim
Holy smokes - that thing is going to fly!!!
Henry
Here it is on the dyno
FANTASTIC
you are right wayne
not to shabby
The traveling Builder
717-773-5624
Erik, that is going to be one fast beast. Once its done you need to make a video of it racing a Blackhawk down an airstrip. I am sure you can make that happen.
With numbers that impressive folks should be able to get a really nice look at:
The Tail Lights!
Very, Very Impressive Indeed!
Erik,
That is awesome, it might just do a burn out in third...
Nice setup and no dip in the horsepowers almost 1 straight line to the top same for the torque. Nice!!
Like the way how your building your car!!
thanks all!
insane brother....insane.
What a great build. Making me want to build one even more. Would you say you and more or less hurdles then your 818 build?
Nolan
So I'm ready for my next project. Just thought is post this here. Look at this on eBay http://www.ebay.com/itm/232445793419
Nolan
nice. The Coupe is more complicated than the 818 but similar in some ways.... so far I would say easiest (if you color inside the lines) - 818, roadster, 33, gen 3 and then GTM... but I am not sure if I would be certain on the 33 vs gen 3... both the builds I did/doing.... were NOT typical builds... so they brought another level of pain with them.... anyway... just my .02....
Thanks for the feedback. I actually meant to post that on my page sorry about that. Well I plan to color inside the lines on the 65 coupe (unlike my 818 build). I feel like I kept erasing the lines and redrawing them lol
Nolan
Well maybe a little outside the lines. I want to use the same motor/trans as you
Nolan
Welp... SEMA is only about 2 months away....
Come on let us see the Blackhawk!!!!
Tease!!!
Henry, let's get together and raid Erik's place and pull the cover off ...
Erik-
Not even a sneak peak for us forum people, huh? You know they name streets after people like you --- One Way! HA ;-o)
I look forward to seeing how everything turned out!!
I do have spy shots available for $50 each...
Weighing complete - cross weight set...
me in it (155 lbs) + 10 Gallons of gas... Full interior with sound proofing, AC/Heat, power steering, some turbo stuff .... so about 2782 without me or gas in it.
Drove it today a bit (2 miles) ....holy crap....yep it's fast...
I can't wait to see it unveiled. I bet it looks AWESOME!
You know that cover is going to damage the paint right? You don't want to pull it off at SEMA and see marks in the paint. For safety's sake I think you should remove it.
