These cars are a little rough riding compared to your daily driver, so you will need to get comfortable with that fact. Like you, I live in PA where the roads are either very good or very bad, so you need to compensate in a way that works for you. My solution is to run 15 psi on the street and 25 psi at the track for the best combination of comfort and performance.
