0
0
OK, two more questions.
Ford TracLoc is the limited slip rear end for Fords. It looks like from this picture that this does have a LSD carrier due to the shape of it. I just wanted to confirm that here. Is there another way to tell if this has the clutches and everything required without taking the rear end apart?
Second, since the bracket that is supplied by FFR uses the lower mount is there a problem if I remove this upper bracket?
