35
155
SteveE
Sean welcome to the fun.
I have GTM 493, have had a good time building lots to look at and plan for as you proceed through the build with lots of help here on the forum. From your pictures I do not see the piece that closes up the front bottom under the radiator. The pieces that Beeman points out should be in another box with the rest of your sheet metal pieces. Do you have the piece that is in the top right of the driver foot box with a hole cut in it for routing your wiring through into the tunnel?
I am also waiting on a Mendy so I will say don't hold your breath for the 5 to 6 month lead time.
good luck with the build list of items looks good.
Thanks for the welcome Sir!! I have the front bottom piece that would be below the radiator, it just happened to be on the floor just out of the pic. I’ll check on the drivers footbox when I get home. Thanks for taking a look.
Blast3r0
Congrats on your kit!
Your pump(s) should depend on your power goals. One in-tank 340 or 450 should be plenty if you are staying n/a and on pump gas. The internal pumps run cooler and are quieter.
I actually have two pumps, one internal on the pass side(corvette driver side) and one mounted externally on pass side. The external pump is on the inside of the panel cubby area directly behind the tank. The cubby area on the other side houses the y fitting for both fuel lines and the return as well as my methanol pump and tank. My external pump is controlled by Holley efi so as to only come on during boost so I don't hear it run all the time.
Wow that sounds like quite the setup. I’d love to see some pics if you have them.
The motor I’m planning on will have a targeted HP of 625 and max torque of around 570. With those numbers any recommendations on fuel pump?
