Thread: Harness Routing Through the Firewall
    Nov 2016
    Petaluma, CA
    Is there any good alternative to using rubber grommets in the firewall and other places to seal the holes where the harness is routed? The holes are 1 1/4" and I would rather not make them larger. Anyone have a better solution? Thanks, Joel
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    Another idea is to use the sealed door jam bulkheads like on the Ford truck doors:
    Legal: 1/30/2020
    Nov 2016
    Petaluma, CA
    Thanks Papa! These are both more of what I had in mind. Just a more finished and professional look I think. Joel
    Seasoned Citizen NAZ's Avatar
    I'm using the American Wire bulkhead connectors that Papa shows in his first post. These are Weather Pack type and look very much like what you would find under the hood of any car and truck made in Detroit. I can highly recommend them as they are a robust design, easy to install, and look professional. But you do need Weather Pack crimpers when working with Weather Pack connectors to make the correct crimp. Yes you could use something else instead of the correct tool but it'd be like driving a nail with a rock.
    Deutsch HDP (flange mount with locking nut for the fixed connector).
