Results 1 to 17 of 17
Thread: Pressure bleed with FF reservoirs
    Kirkland, WA
    Has anyone successfully rigged a pressure bleed cap for the FF polished reservoirs? I don't want to spend more $ on the CNC reservoirs. I could buy another reservoir and mod the cap, but that seems like a waste.
    Thanks for any help.
    Joe
    Motive Products makes caps for many different size master cylinders.
    https://www.amazon.com/s/ref=nb_sb_n...eder+cap&ajr=0
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    Jun 2015
    Fairfax Station VA
    You don't need much pressure; 5 psi will get the job done & certainly less than 10. A bicycle inner tube knotted at one end and slipped over the reservoir body would work. Pump up the tube just enough to make it resist hand pressure and you're good to go. Be sure to check the reservoir fluid level to keep it from running dry.
    MK IV Roadster #8631
    Member grluisi150's Avatar
    Millersville, MD
    I purchased a rubber stopper from McMaster carr https://www.mcmaster.com/#rubber/=1aver9c
    Gary
    Mark IV base kit, 2015 Coyote, Wilwood brakes, IRS-3.55 TruTrac, T56, ABS, PS, Nitto G2, Carbon fiber Dash
    Kirkland, WA
    John - A combination seal and bladder at the same time! Sounds like a plan.
    Papa - I went through the Motive adapters in some detail, but couldn't find any that seemed to match the FF reservoir cap. Probably their universal adapter would work, as it just makes a face seal on the reservoir top.
    Kirkland, WA
    Working off Gary's idea, I found size 6 1/2 Rubber Tapered Round Plugs at McMaster with one hole. I plan to widen the hole a bit and silicone a quick-disconnect in there for my compressor to attach to. 5 psi isn't much, but I figure the plug will pop out if the pressure gets too high.
    Note that I used Size 10 of these same plugs to anchor the e-brake cables in the differential housing 'ears'.
    Thanks for the quick feedback!
    Quote Originally Posted by initiator View Post
    Don't connect it to your compressor! Just use a bicycle pump. Trust me.
    Legal: 1/30/2020
    Lilburn, GA
    ..... I don't want to spend more $ on the CNC reservoirs. I could buy another reservoir and mod the cap, but that seems like a waste.
    Joe,
    Are you planning on adding a second FF brake reservoir? I have one you can have, just pay for shipping. I used a vacuum bleeder.
    PM me .
    When I was making up my pressure bleeder for my CNC MCs I talked to CNC. They strongly recommend a max of 5# pressure. They also strongly advised me to be sure I did not move the brake pedal while I had pressure on the MC.
    I started w/ a piece of radiator hose that would slip over the top of the reservoir and then went to the plumbing section at Ace.
    Pressure Bleeder by craig stuard, on Flickr
    San Diego Ca 92106
    I love that home made tool. simple , practical and cheap.
    Kirkland, WA
    Greatly appreciate all the feedback and support. I'm constantly amazed at the different creative approaches folks use to overcome obstacles.
    David - PM sent.
    Papa - You're concerned about the compressor supplying too much pressure? I could mount a Shrader valve just as easily as a QD and have my son man the pump while I crack the fittings.
    Craig - Thanks for the extra tip about not moving the brake pedal while pressure is on. Hadn't thought that far ahead and might have done it without thinking.
    David - PM sent.
    Exactly! Trust me, I learned the hard way. You only need a few pumps with a bicycle pump to bleed each caliper.
    Legal: 1/30/2020
    Senior Member jwebb's Avatar
    Longmeadow, MA
    Pressurizing the MC to bleed the brakes instead of pumping the brake pedal?
    #9160 BB767's Avatar
    Chehalis, WA
    Quote Originally Posted by jwebb View Post
    The master cylinder reservoirs to be exact. It was the ONLY way I could get all the air out of my lines after trying for two days to do it other ways! For some reason the Wilwood cylinders admit air (around the piston I am assuming) when trying to bleed the conventional way.
    MK4 - complete kit - Blueprint 427W - Holly Sniper EFI - TKO 600 .64 - 3.55 3 link - 17" Halibrands
    Longmeadow, MA
    Quote Originally Posted by BB767 View Post
    Probably why I'm having trouble with my brakes
    If you haven't already done it, you'll want to bench bleed the master cylinders before you start working at the calipers. It's easy to do with the masters mounted in the car. Just attach a piece of tubing from the "out" port on the master cylinder and run it to the reservoir. Pump the brake pedal to cycle fluid through the master until you don't have any air bubbles. Reconnect your brake line and then bleed the calipers.
    Legal: 1/30/2020
    Longmeadow, MA
    I haven't tried this yet but I think it will work!!
