Thread: master cylinders
    Mar 2017
    master cylinders
    I've got the two different sizes .75 & .62. Which one goes on the drivers side and which for the passenger side?
    Quote Originally Posted by eamici View Post
    The larger one (.75) is for the front brakes, which is the one closest to the engine (right side).
    Mar 2017
    Thanks!!!
    Senior Member jwebb's Avatar
    Longmeadow, MA
    Does it make a difference on DS vs. PS as along as the larger MC goes to the front?
    #9160 BB767's Avatar
    Chehalis, WA
    Quote Originally Posted by jwebb View Post
    Nope.
    Probably not, but you will need to adjust the balance bar opposite of the way it is set up to ensure you are applying pressure on the correct MC over the full travel of the brake pedal.
    Chehalis, WA
    Correct, and I suggest you mark each one (front, rear) some way so when you go to adjust them it will be easy to tell which is which.
