Results 1 to 6 of 6
Thread: C5 Steering Column Wiring Schematic
    Senior Member Kempo's Avatar
    Cabo Rojo,PR. USA
    Anyone has a the wiring schematics and pin out for the steering column connectors of the C5?
    Member spytech's Avatar
    Are you referring to the harness I talk about in my post here?
    http://www.gtm-supercar.com/?p=421
    I can get the full pin-out later if you still need it from my c5 service manual.
    Cabo Rojo,PR. USA
    That is the one. Thanks Spy.
    Here is the complete pin-out:
    Connector Part Information: #12092248 23-Way M Metri-Pack 280 Series (BLK)
    Pin Wire Color Circuit No. Function
    A WHT 27 Hazard Flasher Output
    B DK GRN 19 Stop/Turn Lamp Feed-RR
    C YEL 18 Stop/Turn Lamp Feed-LR
    D PPL 16 Turn Signal Flasher Output
    E -- -- Not Used
    F DK BLU 15 Turn Signal Lamp Feed-RF
    G LT BLU 14 Turn Signal Lamp Feed-LF
    H DK BLU 38 Cornering Lamp Control Feed
    J BLK 58 Cornering Lamp Feed-Right
    K LT GRN 11 High Beam Headlamp Feed
    L TAN 12 Low Beam Headlamp Feed
    M -- -- Not Used
    N BLK 150 Ground
    P -- -- Not Used
    R BRN 9 Park Lamp Feed
    S WHT 103 Headlamp Switch Signal-"On"
    T DK GRN 306 Headlamp Switch Output-"Off"
    U ORN 57 Cornering Lamp Feed-Left
    V BLK 28 Horn Relay Output
    W RED 842 Battery Positive Feed
    X RED 842 Battery Positive Feed
    Y LT BLU 74 Park Lamp Switch Output
    Z ORN 240 Battery Positive Feed
    Cabo Rojo,PR. USA
    thanks spy.
    GenII GTM #354
    Delivered (02/09/11)
    no prob
