Results 1 to 14 of 14
Thread: Evans Waterless Coolant is now in stock
    Forte's Parts Connection
    mike forte's Avatar
    Framingham, Ma.
    Hi Guys,
    Evans Waterless Coolant is now in stock.
    This product provides a professional level protection for the inside of your engine and cooling system. With a higher boiling point of 375 degrees and it's anti-corrosion and electrolysis characteristics you can absolutely put to rest that engine and cooling internals are being addressed.....forever. Perfect for you sports car because of the anti-electrolysis and high boiling point and again for your classic car being frozen in time, your cooling system is not going to sour and cause hidden damage. Why worry of hidden electrolysis damage, change it out with Evans Waterless Coolant. It's the best product for the inside of your engine. We've got it, in stock.... here at Forte's Parts Connection. http://www.fortesparts.com/
    https://www.evanscoolant.com/…
    Note: Current rides will need to be pre-flushed with Evans Prep-Fluid to remove water content to below 3%. New rides(new engine builds) do not need the Prep-Fluid.
    #Edlebrock #OfficalDistributor #Ford #engine #factoryfive #Mustang #dragracing #turbo #chevrolet #Camaro #Street #Corvette #Muscle #Cobra #Pontiac #Shelby #Dodge #DragRace #Turbo #supercharger #v8
    Mike Forte: Forte's Parts Connection / Framingham, Mass. 01702 / 508 875 0016 / [email protected] / fortesparts.com / Facebook Instagram: @fortespartconnection Est: 1981 dealing performance parts to build your dream car. A REAL SPEED SHOP with parts, price & knowledge. Developer of the early Ford & FE Tremec and Mustang firewall adjustable quadrant kits, external slave clutch release conversions & cable release conversions. Tremec Elite, FORD RACING & QUICKTIME DISTRIBUTOR!
    Sep 2015
    Hamersville, Ohio
    What is your price? I'm planning to use it.
    mike forte's Avatar
    Framingham, Ma.
    Hi Lance,
    It's fair traded at $45.50 per gallon with free ground shipping on US orders.
    Ask about Forte's discount coupons that are starting next week.
    Placitas, NM
    A number of guys I know over on the BMW E39 forum run Evans. Our V8's (the M62tu engines) run at 108C which develops cooling systems pressure around 20PSI. The side tanks on the radiator and expansion tank are plastic which crack after 6-8 years (sometimes sooner) and leave you stranded until the tow truck shows up.
    With Evans they say they can leave the expansion tank cap loose (for testing) as the cooling system doesn't develop any pressure.
    Sep 2015
    Hamersville, Ohio
    Thanks Mike. Anyone know the approximate coolant capacity of an EJ205?
    mike forte's Avatar
    Framingham, Ma.
    Hi Lance,
    I hope I'm not sounding stupid but what is a EJ205?
    Senior Member 3yearplan's Avatar
    Dearborn Heights, MI
    The EJ205 is the WRX 2.0 Liter (or Litre if you're Canadian/British). The coolant capacity is listed as 7.3 quarts.
    Mark IV 7923 arrived 11-14-12
    DOHC 4.6L, Tremec 3650, 3 Link 8.8 w/3.73
    Sep 2015
    Hamersville, Ohio
    Thank you.
    Senior Member AdamIsAdam's Avatar
    Dec 2019
    Long Island, NY
    Old thread but still relevant. I'd like to convert my FFR MKIV over to Evan's Waterless. I've used it before and really take comfort in knowing there's no pressure so no/low chance of bursting a hose in the summer.
    What's the coolant capacity of the FFR radiator? I have a 302 block, so I'm trying to determine how many gallons I need to buy.
    TIA,
    Adam
    ____________________
    I finally caught a snake!
    MKIV, 347, T5, 3.55. `93 Cobra R brakes, heated seats, PS and lots of custom touches.
    Raleigh NC, OIB NC
    Quote Originally Posted by AdamIsAdam View Post
    TIA,
    Coyote takes 4 gallons with FFR heater & FFR radiator. SB should be similar except to how much the heads hold.
    Kevin
    MKIV #8234
    Dec 2019
    Long Island, NY
    That sounds like a lot. Makes sense given how massive that engine is.
    Senior Member jrcuz's Avatar
    Stafford Virginia
    My 347 and vintage air heater took not quite 4 gals, I bought 5 gals from Mike and have 1 gal and a little bit left.
    JR
    Dec 2019
    Long Island, NY
    Thanks. I should add that I do not have heat
    Jun 2015
    Fairfax Station VA
    My 302 (with heater) takes ~3 1/2 gallons. It starts at 3, but by the time I heat cycle the engine a couple of times I have to add another half gallon at the expansion tank.
    MK IV Roadster #8631
