75
564
..Continued
I'm pleased with the grill - it has proven to fit very well over (and attach to) the FFR radiator, and after studying pics of others will give more ground clearance at very front than the stock '33 grill. It'll also attach to the steel pretty easily - I'll either bend the steel brackets or make some spacers from round tube. There are already slots in steel bracket, so I may not need any more adjustment than that. But if I do, it's easy to add slots in my aluminum bracket.
FFR33 #997 (Gen1 chassis, Gen2 body), license plate DRIVE IT says it all!
build thread
