Thread: FFR#48 Gen3 Daytona Coupe for sale!
    Nashua, NH
    2017 FFR#48 Gen3 Daytona Coupe is For Sale! Street legal race car!
    I am moving to Europe for work and cannot take this great car with me. Rather then letting it sit for many years untouched I want someone else to enjoy this famous race/street car featured in*Grassroots Motorsports multi-page article December 2017 issue. FFR#48 Gen3 Coupe R was also utilized by Factory Five Racing for aero wind tunnel testing, and shock/suspension testing.
    Campaigned in 2017 race season, FFR#48 podium-ed all National Auto Sports Association ST2/TT2 races entered, won 5 out of 7 races and finished 3rd in the other two. It was invited to run at the Grassroots Motorsports Ultimate Track Car Challenge 2017 placing the 7th fastest time out of 50 cars with a laptime at VIR of 1:58.985.
    Laptimes:
    May @ NJMP Lightning laptime - 1:09.249
    May @ VIR - 1:58.985
    June @ NJMP Thunderbolt laptime - 1:25.515
    July @ Pocono Double Infield CCW - 1:33.231
    August @ Limerock laptime - 56.313
    #48 Gen3 Coupe R was built with the help of The Traveling Builder Mark Dougherty, his son Brendan, Sean Lingle and me, starting Jan 1, 2017 and over 5 build weekends in time to make the March 2017 VIR track day.
    On debut, first time on track it lapped VIR* 2:00 on used 245/40/17 Hoosier A7 tires, with the brakes or car not sorted fully.
    http://johngeorgeracing.com
    Nashua, NH
    Over the rest of the 2017 season, the car was fully sorted out, and optimized for NASA ST2/TT2 rules. It does over 2G's in lateral acceleration on race tires, with the top speed of over 150mph. It is well setup and handles neutral to slight under-steer on track. The braking performance is astounding. Setup notes and over 12 years of FFR race car knowledge will be shared with the buyer along with a copy of the race notebook known as 'the FFR#48 bible'.
    This is a serious, multi race winning race/street car and I see no reason why it cannot win at the NASA Nationals 2018 @ Circuits of the Americas (COTA) F1 race track September 2018.
    Nashua, NH
    It was driven on the street many times, and most notably to the 2017 Factory Five Open House from NH over 200+ miles round trip with all of the aero bolted on getting many thumbs ups from fellow motorists.
    Nashua, NH
    Nashua, NH
    Part #s used in the build:*http://www.johngeorgeracing.com/word.../part-numbers/
    Car Setup info:*http://www.johngeorgeracing.com/word...r48-car-setup/
    Pictures from the build:*http://www.johngeorgeracing.com/gall...?/category/382
    All Race Reports from 2017:*http://www.johngeorgeracing.com/wordpress/?s=2017
    2017 Factory Five Type65 Gen3 Coupe R Chassis #005
    1775 Miles, 44 hours on chassis
    Street legal - NH title.
    NASA ST2/TT2 legal - 8:1 weight/power ratio.
    Ford F150 Coyote engine producing 365RWHP
    SCT X4 handheld tuner, along with SCT Race tuning software. Custom tune files to meet hp/weight limits for class.
    Aviaid 4-stage dry sump oiling system for Coyote engines
    4into4 headers
    Custom side exhaust with quiet pipes and interchangeable exhaust tips.
    RAM 10.5" 26spline clutch
    KRC Power steering pump
    Tremec TKO600RR 5speed with .82 5th transmission
    2015+ Ford Mustang Torsen Diff with 3.73 gears
    Custom modified FFR front spindles for better kingpin angle
    FFR IRS using 2015+ Mustang IRS spindles/pumpkin
    Koni 3012 double adjustable shocks
    Heim joints in all suspension
    Wilwood dual master cylinders with cockpit adjustable brake bias
    Wilwood 6-piston front and rear brakes, with .8" thick race pads
    13" Full floating 2-piece Stoptech rotors front and rear
    Removable FFR front splitter with cannards
    Removable APR GT1000 rear wing
    Removable custom rear diffuser
    Pin-on custom Lexan rear hatch
    Trunk fuel fill with access panel.
    22gal Fuelsafe fuel cell with custom 2-sump pickups inside fuelcell for optimal fuel pickup
    Drivers windshield wiper
    Window Defrost
    LED headlights, turn signals, hazards, horn.
    Easily accessible fuse box
    Racepak G2X Datalogging system with IQ3 digital display dash
    Coolshirt driver cooling system
    Custom access panels for replacing starter, getting to bellhouse bolts
    Front and rear tow hooks
    Driver and passenger Kirkey Race Seat
    Driver window net
    Driver side net
    NASA race log book
    Spares list coming with the car:
    1 x Aviaid 4-stage pump with cog wheel, spare cog belt.
    2 x Rear IRS spindles
    4 x Rear IRS axles
    Left and Right 6piston Wilwood calipers
    Race Hawk DTC-70 brake pads
    2 sets of 1 heat-cycled Hoosier A7 245/40/17 on FR500 17x9 wheels
    1 set of 6 heat-cycled Hoosier A7 315/35/18 on XXR 18x11 wheels (CCW replica wheels)
    1 set of rain Hoosier 225/245/40/17 on FR500 17x9
    1 set of street wheels 255/50/17 on FR500 17x9 (raising the car for better street-driving ground clearance by 1.5")
    All F150 spare Coyote sensors, coil packs, fuel rail, engine wire harness, throttle body, etc.
    Ford Racing CobraJet Intake (adds 20-30rwhp) with throttle body
    Used steering rack and outer tie rod.
    Assortment of metric and standard bolts in organizing cases
    fluids (engine oil, trans oil, diff oil)
    clutch cable
    Springs package - lots of 2.5x8" springs
    Asking $65,000. The car is located in Southern New Hampshire.
    [email protected]
    Nashua, NH
    SOLD!!!!!! its going to KY near Bowling Green.
    Sgt.Gator's Avatar
    Bend, Oregon
    Wow, just saw this. I've watched all your build videos, even logging in on the live ones. I need to check the For Sale forum more often! If you don't mind, what was the final sale pice?
    Owner: Colonel Red Racing
    818R ICSCC SPM
