0
0
Remote operated Battery Disconnect?
I would like to control a battery disconnect using a generic remote that will also pop my door solenoids. Any references to a good disconnect would be a big help. I am considering using the intellitec 0100055000 solenoid switch. I've seen hundreds of these things used as battery disconnects in motorhomes and have proven to be bulletproof in that environment. These are passive relays so they only draw amperage during the switching operation. They do require two relays to function but that's simple to wire up. Anyone know of a better way? Thanks
