Results 1 to 2 of 2
Thread: explorer intake & heads
    Member freddiehebert's Avatar
    the classifieds aren't open so i am posting here
    have in stock at the wrecking yard
    1. 1998 explorer intake set up lower and upper with fuel rail and throttle body all complete complete still on the engine also have the gt40 heads available.
    2. 2000 explorer intake set up lower and upper with fuel rail and throttle body all complete complete still on the engine also have the gt40 heads available.
    $250.00 for the intake setups complete
    $250.00 for the set of heads
    $400.00 for everything complete all nuts & bolts
    call me if you want 408-316-0199 thxs freddie
    __________________.
    Southport, NC
    Freddie,
    Those should be GT-40p heads. GT-40p heads could be found after early '97 Explorer production to 2000 and to 2001 for the Mountaineer.
    GT-40p heads are the best flowing stock heads Ford produced for the 302. They can further be identified with four cast vertical strips on each both ends of the heads. There are other ways of IDing them but that is the most obvious.
    George
