Results 1 to 3 of 3
Thread: TKO shifter location
    St. Louis, MO
    For those running a TKO, what location are you using for the shifter? Rear most location?
    Wibby
    Oct 2014
    Vermilion, OH
    Mine is in the stock location (rear), if you move it forward i think you would need a shifter handle that is bent back....or really long arms.
    CVOBill
    Grand Rapids, MI
    TKO-600 I intend to run in the middle with a straight arm. In previous cars this worked well and that configuration had the engine/trans further forward.
    I never really liked the rear position with the forward bend shift arm.
    Jim
