Results 1 to 4 of 4
Thread: Fuel Pump unit
    Mar 2017
    Fuel Pump unit
    Does this setup look correct? FF said it was wrong but for the life of me I can't see another option Hope the pics came through.
    O'Fallon, MO
    Look wrong to me too. I've never seen that kind of sock on an in tank pump. Thats not out of any Ford tanks I've seen. The sock should be long and skinny with the attach point in the middle.
    Senior Member Fixit's Avatar
    Aug 2017
    Minneapolis 'Burbs
    Doesn't look the same or even similar to the pump(s) I received from FFR or Forte's. The filter sock pressed on the extreme bottom end in both cases.
    (Ignore the hoseclamp above the pump... it was so I could press the filter sock on)
    John D. - Minneapolis 'Burbs
    Mar 2017
    This was the model # FF told me I needed to order. I did not get this directly from them. I think something got lost in the translation.
