Page 3 of 3 FirstFirst 123
Results 81 to 87 of 87
Thread: What seats do you have for the 818S
    Frankfort, IL
    Sparco Sprints tuck in nicely. They are a bit snug for daily use (I'm 5'9" 170ish), but I am working on adding a cushion to the bottom to make them a little more comfy.
    Aug 2012
    Long Island
    Sparco Circuit for me, not sure if I am going to get a Circuit II for the passenger seat or another circuit, I have some pretty jacked friends.
    Quote Originally Posted by billjr212 View Post
    Bill did you add the lumbar cushion/side cushions, it pushes you out of the seat a little for some extra comfort and less squeeze
    you can also add another seat cusion to lift you a little bit.
    http://www.frsport.com/sparco-01023n..._p_277059.html
    http://www.frsport.com/Sparco-01022N..._p_277057.html
    http://www.frsport.com/Sparco-01031-..._p_277060.html
    Aug 2012
    Long Island
    Also a lot of people welded, used angle aluminum etc etc to mount the seats.
    these adjustable brackets from Sparco fit the 818 perfectly... about 23" long to hit all the bars
    http://www.ogracing.com/sparco-adjus...de-mount-steel
    San Diego Ca 92106
    Bumping this thread. Wondering if there's any updates as far as the choices you've made in seat selection? ( comfort,durability and fit both in the car and your butt. Lol ) Getting to this stage and I need to pick some seats.
    Has anyone tried the Corbeau CR1 seats in the 818S? Wondering about fitment, as it is a little larger than the FX1 Pro.
    Jan 2018
    Has anyone tried fitting a Tillett B6 seat?
  7. #87
    Sep 2015
    Hamersville, Ohio
    Quote Originally Posted by SarTech View Post
    Yes, I and Aerosti both have the Tillett B6 seats. They fit with room to spare (but not a lot). I purchased the pads with my seats in case the bare seat isn't cutting it. They are a bit pricey tho, around $900 each with pads. The pad option is about $150 per seat. And then there's shipping. Beautiful seats, well constructed, no upholstery to worry about, and they fit me like a glove. The jury is still out as to their comfort on long trips.
