Power Window motors???
I'm guessing the power window motor assy is a left and right hand?
If so I think I have 2 that are the same.
The bracket that mounts to them are a left and right.
Figured one of you guys that have got this far will know as FF won't be open until Monday.
While I was at it I at least got all of the small brackets powder coated today so its not a total loss.
I also found the on-line window switch diagram has a small error in it.
^--This is from the on-line Door Install instructions.
The info in the build manual, page 554 has the correct info for the switch.
Reason: Added info
JimLev
I also found out that the window switch diagram has a small error in it.
Good to know, thanks for passing along the correction!
33' Hot Rod Coupe/Roadster (GEN 1), Fendered, Ford 302, 350hp, EFI, AOD, 4-Link, Double Adjustable Koni Coilovers, Split Rear Exhaust, Electric Power Steering, AC/Heat/Defrost, Moser 8.8"-3.55, Willwood Front/Rear Brakes, 18" x 8" Fronts/20" x 10" Rears, Ordered: 1.26.17, Arrived: 3.29.17, First Start: 7.2.18, Go Cart: 11.4.18 Paint/Body: 2.23.19, Back Home: 11.24.19, Completed: NEVER!; View More Pics @
https://starmobileone.com/
Heard back from FF, they are sending the correct power window motor assy today.
I updated the info about the window switch in my post above.
