Thanks Thanks:  3
Likes Likes:  3
Results 41 to 80 of 109
Thread: mk 4 roadster
    Love The FE With The Dual Four Barrels!
    Also, are those marine flame arrestors topping them off?
    Whatever they are, they look good too and really finish off that Monster Mill!
    Jul 2014
    colorado springs co.
    those are stellings and hellings air cleaners like the ones that came on original set ups with two 4s
    Quote Originally Posted by feadam View Post
    Very Cool To Say The Least!
    Jul 2014
    IMG_8288.JPG closer picture of them
    Jul 2014
    Had to make a trans mount for 4 spd toploader now everything is bolted in. Leveled engine and tightened everything down.
    Senior Member Hacksaw84's Avatar
    Jun 2017
    11 months! Wow I was anxious waiting on the transport shipment. Progress looks good, keep it up.
    Jul 2014
    Wanted to finish in one year but a lot of life got in the way
    It happens to the best of us so Hang On Factory Five Brother, Hang On!
    Adam-
    She's looking great! I have to say though, that with that monster 482 in there, I envision bits of tire flying wherever you go!!
    Congratulations on the progres! It's been fun following along! Looks like the boys have enjoyed the process as well.
    I look forward to watching as you finish her up.
    Jul 2014
    The car should have just under 600 HP, kinda matched parts and cam and may have it chassis dyno'd when done, may not care though depending on how it feels. The boys are a big help, since I retired from military I stay home with them and we seem to do everything together, sports, working out, and garage stuff. We also have a 56 ford truck we are going to fix up some year together.
    Jul 2014
    image.jpgheaders in that was a lot of work
    Jul 2014
    image.jpgsmiths gauges in the dash, I always liked the smiths gauges now I have to wire them
    Jul 2014
    image.jpg original 427 type oil filter adapter, I'm trying to get one thing a day done so the car may be done in the next decade
    mburger's Avatar
    Punta Gorda FL
    This picture is very helpful to me. I want to change my clutch cable and quadrant to a firewall adjustable clutch cable and my Mk1 doesn't have an access panel to the clutch cable quadrant so I am going to cut one out on the firewall. This pic helps a great deal.
    Mark
    Jul 2014
    image.jpg had to cut out center beam for shifter on my top loader to clear
    Jul 2014
    image.jpgsurge tank on
    Jul 2014
    image.jpeg got bored waiting for a couple parts so installed my tredwear billboard kit
    Jul 2014
    image.jpeg leveled car and lowered rear so car wont look higher in back
    Jul 2014
    image.jpgimage.jpghad to take surge tank off and modify because it sat too high for hood clearance. Modified and back on
    Jul 2014
    IMG_8359 3.jpg Car on the move again, moving from maryland to colorado
    Jul 2014
    image.jpeghad new valve covers made with Cobras machined on them
  22. Likes kgkeys liked this post
  23. #62
    Jul 2014
    image.jpeg car is finally back in my garage in colorado
  24. #63
    Senior Member Gromit's Avatar
    Mass, North of Boston
    Is that a cobra body mold in the background? very cool.
  25. #64
    Jul 2014
    Yes I bought them a while ago thinking I would use them to build an aluminum body someday. Seems time is the problem, may never get around to it. The 56 truck in background is ahead of molds
  26. #65
    Jul 2014
    image.jpegbody off for last time hopefully
  27. #66
    Jul 2014
    Has anyone gone out of order on build manual? I don't have wiring harness yet and want to keep going, car wont have many wires, lights, lights for gauges, starter and alternator.
  28. #67
    BadAsp427's Avatar
    Greeneville, TN
    What about water temp, elec fan, oil pressure, ignition, etc... There is a lot of wiring, but having said that, there is lots of other stuff you can do while you wait for your harness.
  29. #68
    Jul 2014
    Gauges are smiths and all mechanical, forgot to list fan and ignition. Anything I shouldn't put in that would hinder wiring instalation
  30. #69
    Jul 2014
    image.jpegimage.jpegput oil cooler together in shroud
  31. #70
    Colorado Springs
    Sweet! I can't wait to see it running.
    .boB "Iron Man"
    www.RacingTheExocet.com
  32. #71
    Jul 2014
    Where are you in Colorado springs
  33. #72
    I am curious where you picked up that shroud. I like the looks of it. Thanks in advance!
    Jul 2014
    From finish line cobra you have to rivit it together around the cooler
  35. #74
    Colorado Springs
    I'm in Rockrimmon, just south of the Academy.
    .boB "Iron Man"
  36. #75
    Jul 2014
    I'm over in flying horse out of north gate, are many cobra owners in springs?
  37. #76
    Colorado Springs
    There are about half dozen or so wandering about the Springs. I don't see them very often, but every now and then.
    .boB "Iron Man"
  38. #77
    Jul 2014
    What do most of you do to inside of body, thinking about painting mine flat black?
  39. #78
    I'm using Raptor Bed Liner, but am either going Black or Red since it can be tinted.
    The stuff is a two part polyurethane product and sprays on.
    https://youtu.be/x_QyUZZ0Ys0
    A lot of folks use Herculiner since it rolls on.
    I've used this stuff before and I think it would be A-Okay too.
    https://youtu.be/V9N6M_VCdpk
  40. #79
    Jul 2014
    that looks like what i am going to use, thanks
  41. #80
    Jul 2014
    image.jpegimage.jpegput ac pedals on my brake and clutch
