Results 1 to 4 of 4
Thread: LS3 wiring harness
    Jan 2019
    LS3 wiring harness
    Any good how to do info on the wiring harness figment for a Bluprint LS3 engine?
    Village Mills, Texas
    Quote Originally Posted by kentsplain View Post
    I'm not sure about the Blue Print LS3. I bought mine from Chevrolet Performance but they can't be that different. Good luck finding a place to put everything. Eventually it all starts coming together. IMG_0005.JPGIMG_0051.JPG
  3. Likes wrp liked this post
    Placitas, NM
    I did away with as much of the plastic corrugated tubing as possible and then wrapped the wires with automotive cloth tape. In most cases it reduced the OD of the bundle by almost 50%. In some cases I shortened the wires, completely removed wires that aren't needed, or folded some to shorten them before taping them together.
    See post 126.
    https://thefactoryfiveforum.com/show...-s-Build/page4
    Aug 2013
    Gatineau, Quebec, canada
    See post 126.
    After seeing what you did and having my son harass me enough i think I will let him do the same!
    Andreas
