Results 1 to 2 of 2
Thread: Daytona windshield install
    Gorham, ME
    For those of you that have done this I have a few questions.
    I bought the same adhesive and trim as Matt (MTWAROG)
    1. I have some 6/32 button head fasteners around the opening to hold the body in place. Do I need to cover them with something soft or will the adhesive cover them adequately? Don't want friction on the button heads to crack the window.
    2. I put door trim around the window opening to create a better finished look for the head liner. I think Matt put foam around the perimeter to contain the adhesive which I like. I figure I can put the foam on the trim which then leaves a nice channel for the adhesive.
    What foam is compatible with the 3M windshield adhesive? Don't want to put it on and then have the adhesive eat it up.
    Thanks!
    wallace18's Avatar
    Trenton, Florida
    I used counter sunk screws instead. But you look like you will be OK.
