Likes Likes:  2
Results 1 to 12 of 12
Thread: New Engine
    Dec 2012
    Houston, Texas
    New Engine
    I have lost compression in my 1991 5.0 and need another engine. I assume that buying a used engine will be must more cost effective than rebuilding the one I have. I need a suggestion for a shop in Houston that can handle a body on engine swap. Thanks.
    Phil: FFR 3121, Frame #2050, Mk 1.5, built 2002, 1991 donor with Blueprint 302 long block and 1993 Cobra intake, BBK 70mm T/B, no smog, power steering, T-5 and 3.55 rear.
    Colorado Springs
    A used engine can be risky, and may not end up being any cheaper.
    Your best bet is a new/rebuilt long block crate motor. The Windsor engines are cheap and readily available. And you'll save a ton of money in shop time if you're paying someone else to do the job.
    .boB "Iron Man"
    www.RacingTheExocet.com
    Dec 2012
    Houston, Texas
    Thanks, Bob. I will check that out.
    Oct 2018
    ada minnesota
    Summit racing
    What About Blueprint Engines?
    From what I hear they do a pretty good job providing cost efficient crate engines.
    https://blueprintengines.com/collect...-crate-engines
    Also, pulling the engine and transmission together may be easier than you might think compared to just pulling the motor.
    It will also allow you to inspect and possibly replace the clutch with a lot less drama.
    Just lift the rear up a good bit and it makes it easier to pop the sucker out.
    https://youtu.be/Vhbftk4AP4k
    Stuffing it back in is easier too.
    https://youtu.be/-nVDzIjSjh8
    Good Luck From The Dark Dart Side!
  6. Thanks BluePrintEngines thanked for this post
    Likes BluePrintEngines liked this post
    Creedmoor, Texas
    You have a PM.
    Texas Cobra Club-Austin
    Senior Member Walt's Avatar
    Dec 2013
    Navasota, Texas
    Hows the engine search going?
    Walt
    FFR8237 Donor build 89 GT , MK 4 , T5 , 17 " hallibrands 9" front 10.5 rear ,4×4 headers stainless mufflers, dual chrome roll bars, coil overs all 4,A/C and heater , soft top, 3:55 gears.
    Dec 2012
    Houston, Texas
    I went with a BluePrint long block from Summit Racing. It is being installed by James Yale at Radical Roadsters in Magnolia, Texas. He is the local Backdraft dealer.
  10. #9
    Dec 2013
    Navasota, Texas
    Great!
  11. #10
    Quote Originally Posted by ptstew View Post
    Awesome, Which Blueprint engine did you get? Most everyone here seems to want to use the 347?
    Kudos for having a shop do it, the guys at RR seem to have a good reputation.Your car will be back on the road quickly, and probably with more power than ever.
  12. Likes BluePrintEngines liked this post
  13. #11
    Dec 2012
    Houston, Texas
    James at Radical Roadsters did a great job and the car is running really strong. I got the BluePrint stock 302 staying with stock 1991 EFI.
  14. #12
    Senior Member Kmcallahan's Avatar
    Jul 2019
    Midland tx
    GoDadGo- I like the way you raised the tail end, enginuity at work!!
