15
211
Originally Posted by
JimLev
Here's what will need some work on to make it look decent.
The other issue with both doors is the rear lower corner, it hits the body before the door closes, maybe some door seals will keep the inside of the door off the body.
I had the same issue and unfortunately ground too much away from the door side and the bond let go between the two skins, so I had to add more fiberglass mat on the inside of the door in that area. I laid three layers of 1.5oz mat on that face lapping onto the top of the door where the window slot would go. I could have added to the body, however I was hesitant to do so as it has multiple layers of cloth and would be harder to get the same strength back due to the strength to thickness ratio of the cloth and resin. Regardless it seemed to work well and will only need to modify the window seal for the power windows.
20181223_104805.jpg You can see the crack in this pic before I corrected it.
Black & Copper #1028 ("The Mistress" according to my wife!
Andreas
