Originally Posted by
Papa
Maybe this will help explain it...
Sorry, Kalvin! I couldn't resist poking a little fun at the People's Republic of Boulder. In all seriousness, if it were that easy to turn a 50% profit building these, I would be on my next build already! Good luck with the build and I hope it works out the way you have planned.
Dave-
Thanks for posting this. Living in Chapel Hill, I can relate to this exact situation! Folks here can be "interesting," in many of the same ways shown in that video.
To the OP, best of luck with your build(s)! As already stated, there are some great folks here with tons of experience that are great at helping folks with their builds. I think you will be surprised at the selflessness routinely demonstrated here!
I look forward to following along, and hope the build progresses in line with your expectations.
Post Thanks / Like - 1 Thanks, 1 Likes
signed up as well....got the popcorn popping!
Good luck with the build and Welcome!
JimLev
That's good to hear, yes it will be a lot sketchier.
You need to start a build thread too.
Our son is living in Evergreen, when I get my 33 done I'll probably drive up there.
Maybe drop in to see your build too.
Awesome, I would love to pick your brain about the 33 if you stop by too!
Looking forward to watching this series and seeing how it all turns out.
Factory Five Racing Roadster MKIV -- #9196 -- 347ci, 475 HP, 5 Speed, Plymouth Prowler Orange Metallic
Ya gotta admit the Rat Fink and the Mystery Machine on the garage wall is pretty cool
I’m on Vspeeds thought process.... wouldn’t be surprised if Kalvin could actually pull something like that off... you never know.
Anyway... welcome Kalvin! I’m subscribed, good luck and I’m looking forward to watching your build.
Kurt
Build thread
Kalvin28 -
where are you at in your build? Did you meet your mark of being a roller "by next week"?
Hey Kalvin,
Can you give your extended family an update?
Here is the latest of 5 videos.
https://youtu.be/JqiMOzUgu6U
Looks like the engine and trans are in. They decided to make it a broad stroke video series, instead of a boring Turn Wrenches series.
Should be starting it soon.
Wow, I'm new to all this but I can't imagine installing or pulling the engine without using an engine leveler on the hoist. Is this common? I pulled and reinstalled mine twice by myself last weekend while fitting the T56 but that was with the leveler.
Mk4, IRS, (Forte: 427 with EFI, T-56 MAG, hydraulic clutch, mechanical linkage, reverse lockout control module) (Breeze: Front and Rear Double adjustable QA1's, Cockpit cubby, LED Lights, Fan Shroud, Fan Lower Support, Oil Cooler Coil, power steering hose kit) (Russ: Drop Trunk, Turn Signal)
miller7448
Da-Bat
How About No Hoist But With An Engine Leveler?
https://youtu.be/Vhbftk4AP4k
https://youtu.be/-nVDzIjSjh8
Swamping It In Da-Swampy South!
Da-Dad
That works! If the engine needs to be pulled with the radiator on, will need to do something similar as the hydraulic cylinder on the hoist will hit. Hopefully it's in for the final time.
