Thanks Thanks:  8
Likes Likes:  22
Page 2 of 2 FirstFirst 12
Results 41 to 52 of 52
Thread: Building a Cobra for a youtube series
    Maybe this will help explain it...
    Sorry, Kalvin! I couldn't resist poking a little fun at the People's Republic of Boulder. In all seriousness, if it were that easy to turn a 50% profit building these, I would be on my next build already! Good luck with the build and I hope it works out the way you have planned.
    Dave-
    Thanks for posting this. Living in Chapel Hill, I can relate to this exact situation! Folks here can be "interesting," in many of the same ways shown in that video.
    To the OP, best of luck with your build(s)! As already stated, there are some great folks here with tons of experience that are great at helping folks with their builds. I think you will be surprised at the selflessness routinely demonstrated here!
    I look forward to following along, and hope the build progresses in line with your expectations.
  2. Thanks Kalvin28 thanked for this post
    Likes Kalvin28 liked this post
  3. #42
    Jan 2016
    Winnipeg, Manitoba
    signed up as well....got the popcorn popping!
    Good luck with the build and Welcome!
  4. Thanks Kalvin28 thanked for this post
  5. #43
    That's good to hear, yes it will be a lot sketchier.
    You need to start a build thread too.
    Our son is living in Evergreen, when I get my 33 done I'll probably drive up there.
    Maybe drop in to see your build too.
    Awesome, I would love to pick your brain about the 33 if you stop by too!
  6. #44
    Nov 2018
    Chandler, AZ
    Looking forward to watching this series and seeing how it all turns out.
    Factory Five Racing Roadster MKIV -- #9196 -- 347ci, 475 HP, 5 Speed, Plymouth Prowler Orange Metallic
  7. #45
    Senior Member SSNK4US's Avatar
    Bakersfield, CA
    Ya gotta admit the Rat Fink and the Mystery Machine on the garage wall is pretty cool
    I’m on Vspeeds thought process.... wouldn’t be surprised if Kalvin could actually pull something like that off... you never know.
    Anyway... welcome Kalvin! I’m subscribed, good luck and I’m looking forward to watching your build.
    Kurt
    Build thread
  8. #46
    Senior Member RickP's Avatar
    Boyertown, PA
    Kalvin28 -
    where are you at in your build? Did you meet your mark of being a roller "by next week"?
  9. #47
    Boyertown, PA
    Any progress??
  10. #48
    Hey Kalvin,
    Can you give your extended family an update?
    Nov 2018
    Chandler, AZ
    Here is the latest of 5 videos.
    https://youtu.be/JqiMOzUgu6U
    Looks like the engine and trans are in. They decided to make it a broad stroke video series, instead of a boring Turn Wrenches series.
    Should be starting it soon.
  12. #50
    Apr 2018
    Colgate, WI
    Wow, I'm new to all this but I can't imagine installing or pulling the engine without using an engine leveler on the hoist. Is this common? I pulled and reinstalled mine twice by myself last weekend while fitting the T56 but that was with the leveler.
    Mk4, IRS, (Forte: 427 with EFI, T-56 MAG, hydraulic clutch, mechanical linkage, reverse lockout control module) (Breeze: Front and Rear Double adjustable QA1's, Cockpit cubby, LED Lights, Fan Shroud, Fan Lower Support, Oil Cooler Coil, power steering hose kit) (Russ: Drop Trunk, Turn Signal)
  13. #51
    Quote Originally Posted by miller7448 View Post
    Da-Bat
    How About No Hoist But With An Engine Leveler?
    https://youtu.be/Vhbftk4AP4k
    https://youtu.be/-nVDzIjSjh8
    Swamping It In Da-Swampy South!
    Da-Dad
  14. Likes miller7448 liked this post
  15. #52
    Apr 2018
    Colgate, WI
    That works! If the engine needs to be pulled with the radiator on, will need to do something similar as the hydraulic cylinder on the hoist will hit. Hopefully it's in for the final time.
