Results 1 to 6 of 6
Thread: Thread sealant on IRS differential drain and fill plugs
    May 2018
    I'm filling my IRS with gear lube. It appears there's some type of thread sealant on both the fill and drain plugs. Should I put some type of sealant on the plugs when I reinstall and if so what does everyone use for this?20191029_184702.jpg
    Apr 2019
    NC
    Yes, you can use Permatex High Temp 59214
    They are pipe thread, you don't really need anything on them. They have no pressure on them so just snug them well, and it'll be OK.
    Jax Beach, FL
    I use Permatex thread sealant.
    rich is correct, but I hate leaks. The down side of using sealant is that you need to clean the old sealant off each time.
    Edmonton Alberta
    on pipe thread I use teflon paste, if you do it up dry it will likely leak. I don't like teflon tape because little pieces can come off and get into bearings and plug off small oil passages.
    David W
    Mkll 4874 built in 2004
    Senior Member mlewis's Avatar
    Mar 2017
    Groton, Massachusetts
    2x on Permatex High Temp
