Thread: Help please, OEM C5 fuel pump line identification
    Senior Member beeman's Avatar
    Indiana
    I couldn't find this in the buildmanual or Corvette sites...
    Red1 dumps into the fuel tank
    Red2 is a hard line off the fuel pump
    Red3 is connected to the pump housing via a flexible line
    Green 1 enters center of fuel filter
    Green 2 is adjacent to Green1
    Green 3 leaves the filter, I believe to the fuel rail?
    What gets capped vs connected?
    EDIT: Found this diagram, thanks again guys!
    GTM #304 LPE 525hp LS3
    Apr 2019
    As you are doing such a great job with this build of yours, I would personally recommend using the 2004 and later in tank fuel pump, a bit more expensive, but boy is is easy to connect and disconnect, I have had to removed my tank few time, I have is one quick disconnect and done, not even one drop of fuel. I also have no cross connections and will never leak, two pump, and hardware to control them.
    Mostafa
    This is from memory....so no guarantees here.
    Red 3 is fuel pump pressure
    Red 2 is return line from fuel filter.
    Red 1 is/was the return from the jet pump in the opposite tank.
    Green 3 is the output that connects to fuel rail on engine.
    Green 1 or 2 connects to pump pressure or return and vice versa....I do not recall which is which off the top of my head.
    So really, the only port that gets capped off is Red 1.....assuming you are also capping off all lines in the GTM non-pump tank.
    Shane Vacek
    www.vraptorspeedworks.com
    Apr 2019
    This Simple with intank version.
    Just looked at the GTM in the shop here and I had Red 2 and Red 1 reversed.....I just edited/fixed that in my post above. And the car I have out here is not using the OEM filter, so I'm still not sure which of those are which from memory....
    Shane Vacek
    Member claybags's Avatar
    rio rico,az
    Dave,
    On the filter … 1 is the return line to the tank, 2 is the pressure feed from the pump, and 3 is out to the fuel rail.
    cheers and happy holidays, Jeff
    GTM 422, LS6, cam, heads, Mendeola trans
    Indiana
    Thanks guys!
    Merry Christmas!
