Results 1 to 6 of 6
Thread: rear shock help
    Senior Member jwhit's Avatar
    Oct 2019
    north carolina
    rear shock help
    got my shocks yesterday installing today on 8.8 ford solid axle somthing seems wrong if axle hangs free looks like driveshaft
    would hit frame !! should there be limit straps installed?? please help
    Norton, MA USA earth
    Pretty sure the limiting straps were only for donor shocks and springs. If your concerned you could add them.
    mike
    Super Moderator
    Ray's Avatar
    La Mesa, California
    I just installed new shocks and asked that same question. Had Pro-Shocks front/rear and installed the limiting cables that came with my MK-II kit. Switched to some high quality double-adjustables and checked on the use of the cables. I emailed the vendor, the manufacturer, a pro-builder and FFR. Got two different responses back. Two said "Yes, you need to limit the drop of the axle" and the other two said "No, they're not needed."
    So, just to be safe, I re-installed the cables. Figured it can't hurt.
    Ray
    Senior Member bil1024's Avatar
    NY
    Yeah I may have the same situation, going to see when I get driveshaft installed, and go from there, never got any straps with the kit
    Oct 2019
    north carolina
    Quote Originally Posted by Ray View Post
    Ray
    i think i will make some straps
    Unless you're making like Bo and Luke Duke you'll never have the axle at full droop while moving.
