Thanks Thanks:  11
Likes Likes:  72
Page 2 of 11 FirstFirst 1234 ... LastLast
Results 41 to 80 of 415
Thread: Street Rod Jim's 33 Hot Rod V2 #1143 Build - The Journey Begins
    Senior Member JOP33's Avatar
    Haslet, Texas
    May want to also put a second nut on the tie rod to allow for adjustment with out damaging during turning.
  2. Likes shmelty liked this post
  3. #42
    Arizona
    Quote Originally Posted by JOP33 View Post
    I had to use rack limiters on mine. You will likely run into issues with the inbound side of the bike fenders hitting the control arms at full turn...you may want to relieve them prior to paint.
    Yes, I am going to get some mustang ones when I am ready. Thanks.
    33 Hot Rod V2 Coupe, Extra Clearance Hood, Bike Fenders, Rear Exhaust, LS Engine
  4. #43
    Arizona
    It has been a long journey up to this point, but I feel like I am finally getting somewhere.
    Wrapping Up Phase One
    My HVAC install has some clearance issues.
    HVAC Installation
    After a long struggle with some stainless steel, I am finally mocking up my Front Grill/Radiator
    Front Grill Mock Up
  5. #44
    Arizona
    Now that I have my spray guns setup I am tackling some painting at home and color matching my calipers to the outside of the car.
    Painting And Assembling The Brake Calipers
  6. #45
    Arizona
    Steering rack is running into the suspension.
  7. #46
    Arizona
    Installing brake lines on the 33 Hot Rod V2
  8. #47
    Arizona
    Sizing up the front bike fenders
  9. #48
    Arizona
    Factory Five 33 Hot Rod V2 Build - Wrapping Up Phase 1
  10. #49
    Arizona
  11. #50
    Arizona
  12. #51
    Arizona
    Factory Five 33 Hot Rod V2 Build - Painting And Assembling The Brake Calipers
  13. #52
    Arizona
    My frustrations builds from hitting many walls at once.
    Factory Five 33 Hot Rod V2 Build - Trunk Paneling - Reality Check
  14. #53
    Arizona
    Factory Five 33 Hot Rod V2 Build - Crazy Transmission Purchase - Chaotic to say the least.
  15. #54
    Arizona
    So I have really been struggling with the gas tank fitment, but I think I finally got it.
  16. #55
    Arizona
    I am happy to get this front end dialed in and completed for the most part.
  17. Likes wrp liked this post
  18. #56
    Arizona
    The abatement plates are causing an issue on my brakes. It is not the paint.
  19. #57
    Arizona
    I did a lot of research on Lizardskin, Upol Raptor Bed liner and you really can't find much on actual spraying it on the vehicle and what to expect. All you get it mask everything off and splatter it on. In this video I show you how intricate you can get with spraying this product for a super clean look.
  20. #58
    Senior Member Caddy Dad's Avatar
    Jun 2019
    Scaggsville MD
    Hey Jim,
    If you want to remove those gear rings (I think they're called tone rings) on the front hubs there is a really easy way to do it. Take your dremel tool and cut about 2/3 or so the way through it and then insert a screwdriver in the slot you just cut and then hit the end of the screw driver with a hammer. The ring will just crack into two pieces. It s very brittle metal. Took me about 15 seconds to remove mine. (Credit to edwardb)
    Keep up the good work with the videos!
    Mk IV Roadster #9749, Kit received Jan 2, 2020, Blueprint SBF 347 TKO600 Holley Sniper EFI, Dual roll bars, IRS, 17" Halibrand, Nitto 555 G2 245, 315 Road legal Oct 20, 2020
  21. #59
    Arizona
    I was able to get all the AN fittings and hose to plumb out my fuel rails and fuel lines on the car.
  22. #60
    Apr 2019
    Thank you for your video series. I’m planning on FFR kit but probably a few years away yet. These videos give a true picture of what to expect. I’ve been reading a lot of these posts for almost a year now and this has been the most helpful so far.
    Thanks again
    J. Larson
  23. #61
    Arizona
    Quote Originally Posted by Salty Chief 35 View Post
    Thanks again
    J. Larson
    I appreciate the comment. This is exactly why I am doing this build this way. I really wanted to show a realistic build from "the guy with a few tools in his garage"; just how they advertise to us.
  24. #62
    Arizona
    Excited to get this engine mounted.
  25. #63
    Arizona
    In this video I show installing all the components around the engine; Brake reservoir, Overflow tank, Dryer, Fuel Regulator, Dip Sticks, Headers, Down pipes.
  26. #64
    Arizona
    Here is some information on LS engine CPU, PCM, Gas pedals, throttle bodies when rebuilding an LS engine. I also talk about Holly Terminator aftermarket systems.
  27. #65
    I realize you’re probably miles ahead, but chopping that pedal and using the supplied ffr pedal is silly easy.
    33 Hot Rod #1133. LS/TKO600
    Titled 2-28-20
    MkI.IV 2643k
  28. Likes shmelty liked this post
  29. #66
    Arizona
    Quote Originally Posted by sethmark View Post
    Keep in mind I have never welded before and do not have any equipment for that.... Mr Seth, the Expert Fabricator! LOL. Easy is relative statement.
  30. #67
    Quote Originally Posted by Street Rod Jim View Post
    Mine is bolted, mr YouTube fame! Lol
    Titled 2-28-20
    MkI.IV 2643k
  31. Likes shmelty liked this post
  32. #68
    Quote Originally Posted by Caddy Dad View Post
    Hey Jim,
    You can also heat them up slightly and they fall right off.
  33. Thanks shmelty thanked for this post
  34. #69
    If you are going aftermarket, why not ditch the drive by wire set up all together and just go with cable drive TB? then you can use any pedal you want
  35. #70
    Nov 2019
    Jacksonville, Florida
    SRJ,
    I really enjoy your videos and look forward to seeing the finished product!
  36. #71
    Apr 2019
    Computers and motors... they’re great when everything works but will make you pull your hair out when there’s a problem. Glad you got it figured out. Keep up the good work and thanks again for your video posts.
    J. Larson
  37. #72
    Arizona
    Installing the Rear Exit Exhaust had a few snags with V2 33 Hot Rod
  38. #73
    Arizona
    Drive System Fitment for the small 33 Hot Rod V2 engine bay.
  39. #74
    Arizona
    So it looks like I have to move my rear shocks again!
  40. #75
    Arizona
    Finally finishing up the firewall.
  41. #76
    Arizona
    For the 33 Hot Rod V with an LS engine - 4L60 Transmission, you will have clearance issues and need to move the engine forward.
  42. Likes Mrallsport32 liked this post
  43. #77
    Arizona
    Kit Car Talk with Street Rod Jim - Overview of the current progress
  44. #78
    Sep 2015
    Bridgewater, MA
    Do you really have to wait for the car to be on the ground to start body work and door fitment? I have seen many other builds that started with body/doors before mechanical work. Many have stated they wished they had started with body first.
    '33 Hot Rod Gen 2 Roadster #1209, 33 Grill, 3-Link Rear Suspension, Leather Roadster Seats, Electric Assist Steering, Rear Exhaust, 2 Piece FFR Bonneville Wheels (18x9/20x11) Mickey Thompson Street Comp Tires (255/45/R18 and 305/35/R20), '69 Ford 351w (Stroked to 393. All Forged), AOD, 8.8 31 Spline Rear with Trac-Lok, QA1 PromaStars (Front 9" 220lb/Rear 12" 200lb Springs).
  45. #79
    Arizona
    Quote Originally Posted by shmelty View Post
    If you want to set yourself up for success and only do it once with less chance for error; YES. You do not have to finish the car all the way, but putting it on the ground changes things. I could not imagine getting everything perfect and then putting the car on the ground to see everything off. There is sag to the frame with the removal of multiple jack stands from the center of the car, however minute, will change the door gaps since they are minute and obvious to the eye. Bolting on the waterfall changes things. I am told to make sure I bolt on my Hardtop first too since it will change things. When cutting fiberglass, sometimes I feel like the panels are magically growing in between cuts, because things shift as they fall into place. Once they are in place, I want it to be the final resting place.. and that is with the car on the ground.
  46. #80
    Arizona
    There is clearance issues with the 4L60e transmission. I have to dial in the height so the driveshaft of the Factory Five 33 Hot Rod V2 so it is positioned correctly.
