Thanks Thanks:  2
Results 1 to 3 of 3
Thread: Heater flow direction
    Nov 2016
    I'm not 100% sure, so I'll just have to ask to confirm:
    When plumbing the heater/defroster (to my BPE 347):
    Right outlet on heater (closest to center of car) connects to water pump, with the control valve inline
    Left outlet on heater (towards PS of car) connects to intake manifold
    Is that correct?
    Secondly, is the water pump pushing or pulling coolant through the heater system? Newbie just trying to understand.
    Thanks!!
    Alliston, Ontario, Canada
    Flows intake manifold to heater then returns to water pump. Usually plumbed into drivers side and out PS of heater core but not sure it matters.
    2017 FFR MK4 9026, 3 Link, 15" FFR halibrands, cooper cobra tires, '88 302/5.0, GT40 Y303 heads, Performer RPM intake Manifold, Holley 650 DP Carb, Pertronix distributor, T5Z spec built transmission, 3.73 rear end. Ordered Nov 2016, picked up at FFR Feb 2017, first start July 2017, Legal on the road May 2018, still in Gelcoat.
  3. Thanks IowaBen thanked for this post
    So. Bay (So. Calif.)
    Quote Originally Posted by Murd View Post
    That's how mine is plumbed. Intake, to shutoff valve, in DS, out PS, to water pump.
  5. Thanks IowaBen thanked for this post
