Results 1 to 18 of 18
Thread: Handbrake Cables
    Oct 2018
    Handbrake Cables
    Good Morning
    Im running my handbrake cables, standard rear calipers on my axle 3 link , round the back of the shocks etc
    But not sure where to go as the length doesn't seam right
    I have 2 holes in the chassis by the tunnel which the outer cables can slot into but the inner isn't long enough to reach the lever clevis on the lever
    I also have a bracket in the kit, not listed in the build Manuel where to fit it if its to do with the brakes but listed as a 'e brake cable mount' on my parts list so assuming i need that
    Any pictures where everyone has mounted on the chassis please
    holes in chassis
    bracket
    Thanks Guys
    Falmouth, MA
    the angle bracket mounts on the bottom of the floor and the cable sheath locks into the holes to hold the end of the cable the correct distance from the cable attachment point on the hand brake lever. The 2 holes in the frame could be used for the cables to run through although I did not use them. The e-brake cables come in various lengths depending upon which rear brakes and what year car the cables were selected for. The attachment of the bracket is shown on page 300 of the manual.
    Is this a gen2? My gen1 doesn't look anything like that..
    Oct 2018
    Yep ive a Gen 2 chassis,
    The holes in the chassis are for cables but not mine hence the extra bracket
    Oct 2018
    Quote Originally Posted by cob427sc View Post
    we must different books for Gen 1 and gen 2 chassis as not on page 300 in mine
    but thanks for the reply, mounting to the floor it is
    Senior Member UpNorth's Avatar
    Jan 2018
    Baie Saint-Paul, QC
    Grusks,
    I am building a Coupe right now.
    When time came to install my e-brake cable I was puzzled because the fit was not right.
    After a lot of searchs I sent an e-mail to FFR with pics of the cables.
    They came back to me saying they sent me me the wrong ones. They sent me the right ones right away.
    Could this be your problem?
    Senior Member sethmark's Avatar
    Virginia International Raceway
    I ran the cables up the rear arms to the supplied bracket. Used these cables - raybestos bc95740
    I'm not sure what the issue was gen 1, but there was a bunch of discussion about flipping calipers around... ignore that entirely. Use the Raybestos cables and factory bracket and it works flawlessly.
    33 Hot Rod #1133. LS/TKO600
    Delivered 6-17-19. Started work 7-3-19. First start 9-6-19. First drive 9-24-19
    Titled 2-28-20
    MkI.IV 2643k
    Senior Member Blade's Avatar
    Apr 2019
    Dunlap Tenn
    I got some good advice on e-brake cables. Here is the link to what I used. Take Sethmark's advice. https://www.rockauto.com/en/moreinfo...362743&jsn=968
    Did I get that from you and not give credit? I’m sorry!
    Titled 2-28-20
    MkI.IV 2643k
    Falmouth, MA
    The installation of the bracket is shown in the manual, my manual is Revision 3B on page 300. Shows exactly where and how to mount and uses at least bolt that extends through the e-brake handle to secure everything together.
    Oct 2018
    Ive got a gen 1 book with a gen 2 chassis, just downloaded the G3 book, and will get the wife to print it out, having a quick ready so many changes that explains why some of must stuff didn't fit or have been changed and dont match my original book
    Thanks for the tip there are newer versions of book
    Spence
    Oct 2018
    Quote Originally Posted by sethmark View Post
    Perfect
    Many Thanks
    Oct 2018
    Quote Originally Posted by RoadRacer View Post
    Yep ive a Gen chassis which has different holes and by the looks of it also wrong cables to match the bracket
    Apr 2019
    Dunlap Tenn
    No apology necessary. I probably didn't word my response very well. You gave me advice on the e-brake question and it was spot on.
    Apr 2020
    Underwood, IA
    I was confused also. Building mine with IRS and the 13" brakes. The cable routing guidance in my manual (3D) is not explained well for this configuration. I'm also not seeing the bracket and it's not explained in the manual either. My chassis looks just like Grusks picture. Any advice or pictures on how to route the ebrake cables on this IRS 13" brake configuration?
    Aug 2013
    Gatineau, Quebec, canada
    Quote Originally Posted by russwaggs View Post
    I have a Gen1 and routed mine this way with the IRS setup:
    20200424_081719_resized.jpg 20200424_081729_resized.jpg 20200424_081746_resized.jpg 20200424_081751_resized.jpg
    Andreas
    Apr 2020
    Underwood, IA
    Thank you!
    Oct 2018
    Many thanks everyone
    I ordered the the above ones from Rockauto last Thursday and arrived today ( and im in London UK ) WOW
    Home schooling / lockdown is now finished for the day as its 2.30 pm so i can now go in my workshop and fit them
