Hello i will take delivery of a MK4 in early July, i am using a 2013 Truck 5.0 and a 2007 TR3650. does anyone know the correct Ford Part Number for the right computer and harness?
I believe you'll want the Gen 1 Control Pack, which is M-6017-A504VB
If the engine harness is still attached (for injectors, coils, etc) then it should be all you need.
*edit*
You'll want to replace the exhaust cam with the Mustang GT ones or be sure to get a tune early. I'd personally save the cost and trouble of replacing the cam and just get a tune.
Gen 3 Type 65 Coupe builder
Now aware that Ford Performance makes a control pack that directly plays for the truck version of the Coyote. According to their notes, "truck engines require modifications." Not sure what that means. Google found this: https://lmr.com/products/what-makes-...gine-different.
