Likes Likes:  9
Page 2 of 2 FirstFirst 12
Results 41 to 47 of 47
Thread: Whitby power brake kit
    Folsom, CA
    Arrow
    ok this kit has been around for 10+ years - instead of using a template next time, I'll just use the Replicaparts.com Brake Booster Spacer
    $39 shipped and will seal the booster against the footbox nicely instead of air-gapped spacers...
    my first challenge was drilling out the center hole (2 3/4" hole saw)
    now - to mount the power booster, it looks like I'll need to cut/trim the wilwood pedalbox more!
    the top bolts won't be able to fit a nut when mounted flush...
    ideas for clearance? I thought I saw pics where someone used a smaller hole saw to cut a circular area around the bolts?
    Todd
    Helicopter Wrench-Bender ChopperJustin's Avatar
    St. Georges, DE
    Check out post #19 by Kp on this thread. Looks like he used a "?" diameter forstner bit/hole cutting bit and cut out the material and then re-powder coated in red.
    "Gravity, It's The Law"
    Folsom, CA
    Quote Originally Posted by ChopperJustin View Post
    ah yes i see now, I will probably try my hole saw ~1 1/8th and give it a try...
    Todd
  4. Likes ChopperJustin liked this post
  5. #44
    Folsom, CA
    trimmed with a 1 1/4" hole saw, worked great!
    still had to trim the lower portion of the pedalbox mount because it conflicts with the steering bearing when you pull it inside the footbox
    https://thefactoryfiveforum.com/show...l=1#post412193
    Todd
  6. Likes ChopperJustin liked this post
  7. #45
    mcwho's Avatar
    DeBary - Florida
    I unstalled the Whitby PB kit in my Non-donoR MK4. The only thing i changed was I used a master cyl from Speedway to get the correct ratio, woks great. The holes in the frame mounted up to the PB unit just fine.
    Baghdad Bob
  8. Likes toadster liked this post
  9. #46
    Folsom, CA
    Quote Originally Posted by mcwho View Post
    what was the different using the speedway master from the bendix master that whiby provides?
    what was your pedal distance from the back of the footbox?
    Todd
  10. #47
    mcwho's Avatar
    DeBary - Florida
    With the firewall forwad kit I didn't have enough clearance or verticle room to mount the emote resevoi units. The one I used from Speedway has an integral snap on lot, speedway pat link is here. 1 Bore
    https://www.speedwaymotors.com/Alumi...ore,50598.html
    I have about 4" of clearance from the pedal to the alum panel.
    Baghdad Bob
