Likes Likes:  2
Thread: SOLD 1966 Chevy Truck Frame Off Build Trades for Factory Five
    Feb 2020
    Greater Phoenix area
    1966 Chevy C20 ¾ Ton Custom Truck
    Professional frame off complete restoration/upgrade with top quality components. This truck has it all. Cost of build exceeded $ 60,000. Unfortunately the original build info is not available. This is an exceptionally well built truck that runs, stops and drives amazingly. Built to show, tow or tour the town it is as clean on the bottom as it is on the top. Less than 2500 miles on build.
    Frame and Body:
    Complete suspension overhaul front and rear.
    Front and rear sway bars
    Panhard bar
    Later model Chevy large front disc brakes
    Rebuilt factory rear drum brakes
    All new brake hoses
    New chrome brake master and booster
    Rebuilt factory rear end with posi 3.23 ratio
    Dual custom built 20 gallon steel fuel tanks with locking
    fuel caps hidden in bed
    Fuel transfer pump with Carter pump cab controlled
    All new fuel and vacuum hoses throughout truck
    Stainless steel drop down battery box mounted on frame
    4 gas shocks
    High volume underbed mount vacuum pump with Crane vacuum tank
    Class III 5,000 lb trailer receiver hitch
    Drop down locking rear underbed mount spare tire
    Urethaned Hardwood bed with Stainless steel rails
    New Painless full wire harness and fuse block
    Custom Acrylic Enamel with hardener white paint inside and out.
    Inside of cab, underhood and engine bay painted to match
    Lizard skin sound deadener inside cab and bed sides, front and rear fenders
    All new glass in cab
    New black carpet with insulation
    Tilt chrome steering column
    Custom steering wheel
    New Sony Mex-XB120BT Stereo 6 speaker, CD, Sirius ready, Blu tooth
    Electronic hidden radio antenna
    Custom covered original seat Black with tweed insert
    New retro seat belts (3) includes an additional spare belt
    Original jack and lug wrench
    Full set Auto meter gauges dash package billet aluminum insert
    Transmission temp gauge
    Underdash air conditioning
    New door handles, arm rests, sun visors, glove box, inside and outside mirrors
    New weather strip throughout cab
    Drive train:
    Over $12,000 cost of motor build
    454 Chevy block (have rubbing on numbers)
    Bored to 486 or 502 CID ?
    Moderate cam grind
    Chevrolet performance aluminum heads
    Roller cam Roller rockers
    Chevy factory 425 HP 427 aluminum intake manifold
    Serpentine billet aluminum belt system
    Power steering unit
    Chrome alternator
    Fi Tech 600 HP fuel injection # 30002
    Mallory Unilite distributor
    MSD 6A Capacitive discharge ignition
    Mallory Super coil
    Taylor Spark plug wires
    Moroso deep oil pan
    Hedman long tube ceramic coated headers
    Custom air cleaner dual snout forced air ducting with K&N element
    Aluminum radiator
    Electric cooling fan with Flex a lite controller box
    Race Craft Turbo 400 transmission
    Deep trans pan with cooling tubes
    Dyno Max polished stainless steel mufflers
    2 inch dual exhaust rear bed exit
    Eagle Alloys Slotted aluminum wheels
    225/65/R16 tires
    $ 32,500 No trades
    Call Wayne at 602 390 7834
    Phoenix area
    Special note***
    Yes this truck is a long bed ¾ ton. Many people prefer short beds and ½ ton trucks. Driving this truck down the road and at car shows it receives a lot of attention. Thumbs up, high fives and just waves. The general public doesn’t really know the difference they just see a beautifully built truck with the right stance sounding mean cruising by. I doubt you could build a truck like this for the asking amount. Also open to trades or partial trades. Especially a Factory Five 33 roadster or 1935 Truck built or partially done. 1968 1969 or 1970 AMX restored.
    For additional pictures especially of the bottom of the truck, which is as clean as the top, see ads on Racing Junk.com, Craigslist Phoenix or contact me and I can email them to you.
    Thanks for looking !!
  2. Likes shmelty liked this post
    Seasoned Citizen NAZ's Avatar
    Wayne, you have a sweet looking ride -- looks way better than the day it rolled off the assembly line.
    Feb 2020
    Hey thanks. I wish I could have added more pictures as the bottom is as clean and well done as the top !! You can see more pics on RacingJunk.com or Phoenix Craigslist.
    Your input means a lot as I have seen the quality work on your car.
    Thanks, Wayne
    Feb 2020
    Some additional pictures:ATTACH=CONFIG]128012[/ATTACH]https://thefactoryfiveforum.com/attachment.php?attachmentid=128012&d=1589113484&th umb=1&stc=1https://thefactoryfiveforum.com/attachment.php?attachmentid=128013&d=1589113680&th umb=1&stc=1https://thefactoryfiveforum.com/attachment.php?attachmentid=128014&d=1589113741&th umb=1&stc=1https://thefactoryfiveforum.com/attachment.php?attachmentid=128015&d=1589113785&th umb=1&stc=1https://thefactoryfiveforum.com/attachment.php?attachmentid=128016&d=1589113844&th umb=1&stc=1https://thefactoryfiveforum.com/attachment.php?attachmentid=128017&d=1589113940&th umb=1&stc=1https://thefactoryfiveforum.com/attachment.php?attachmentid=128018&d=1589114005&th umb=1&stc=1
    Feb 2020
    Okay just to let everyone know the truck has been sold and will soon be on it's way to a new home in Ohio. One step closer to a new build on a FFR 33. Thanks everyone for your interest.
  7. Likes shmelty liked this post
  8. #6
    Mar 2018
    Yucaipa, CA
    Wow,, that might have been a real temptation.... Have 33' here #1095... Maybe 1/2 way done. All new, motor & trans in wiring in place but not completed.... Ready to start,,, Then the dreaded old man fear,,, Heart Attack. By the Grace of God, Talented Doctors and the wonders of modern Chemistry,,,, I Live. But very stalled for about 1 year now. I am all on Board with Dave Smith and BUILT not Bought,,,, but now thinking Driving might be a good thing as opposed to Not Finishing.... Not out yet,, I'll get back too it. But Temptation is always there. Nobody in family is interested, they could not even drive a 5 speed or sadly, turn a wrench. Its all good and Just Happy to be part of this Talented group....
