Page 2 of 2 FirstFirst 12
Results 41 to 44 of 44
Thread: Power Steering options for the Gen2GTM?
    Senior Member mikespms's Avatar
    North Miami,FL
    Hi Vidal. I spoke to Jim at factory five today went over the setup and the way I mounted the rack he thinks it will work . nothing that can't be corrected with a bump steer kit if needed,as soon that i can get the car on it's wheels i will check the toe thru the travel of the suspension. I am going to instal swaybars front and back as well.We talked about the shock mounts he is working on a bolt on fix won't have to take the panels out to do.
    Member kabacj's Avatar
    For the sake of completeness, this is what I ordered from Toyota to complete the MR2 based setup
    XTF #2
    build start date June 19 2023
    GTM # 344
    Build Start December 2010
    First track day April 2013
    Senior Member VD2021's Avatar
    Central, FL
    Mike, PM.
    R/s
    Vidal
    BUILD LOG AND WEBSITE:
    http://gtmbuild.weebly.com/ .
    Do you have parts #'s and source info on the lines connecting the pump to your rack? This is great info, thanks.
