Thread: Fluorescent Dye
    May 2018
    Merritt Island, FL
    Fluorescent Dye
    Has anyone used the fluorescent dye you add to the oil to find a leak?
    Colorado Springs
    Yes. It worked well, and I found a small leak at the rear through the O-ring on the oil filter block.
    .boB "Iron Man"
    www.RacingTheExocet.com
    Seasoned Citizen NAZ's Avatar
    Yes, but never saw a need on a passenger car. Most of the fluids used on a typical passenger car are different enough to determine the source.
    But if that's not the case with your application then you may want to invest in a fluorescent dye marker. When I was a Reliability Team Mgr at Disney, we'd use dye to detect which attraction vehicle was leaking oil on the track. Here's some info on how dyes are used: https://www.knowyourparts.com/techni...vy-duty-fleet/
  4. Thanks WIS89 thanked for this post
    May 2018
    Merritt Island, FL
    I know it's engine oil, just not 100% where it's coming from.
    Cape Coral, FL
    Yes I've used it and it's GREAT!. I thought I had only one leak and turned out to be 3 separate ones. It is very useful when you are trying to track down oil leaks on the back of the engine. I had one on a valve cover, one on the intake and then one at the back of the oil pan. As I torqued each and wiped they sealed up one at a time and made it easy to track each one and make sure all were gone.
    i have not used oil dye but the Ac freon dye w/ a black light is fantastic.
    Senior Member Jetfuel's Avatar
    Aug 2018
    Indianapolis
    The additives in synthetic oils will glow without dye
    Turn the lights off in the garage and wait at least two minutes for your eyes to get used to the dark environment then get to find the leak
    IIR the maximum white light for dye inspection is 1 candle power so it’s got to be pretty dark
