For those doing Mike Forte's Hydraulic Clutch system on a T5, it's pretty straight forward...here is what I did:
1) Drill 2 holes in the bellhousing using the bracket as a template
2) mount bracket inside bellhousing
3) mount clevis bracket onto clutch fork
4) Figure out how much you need to cut off the pushrod...in my case it was 1-3/6", that left me about 1/8" end play
5) install slave cylinder to bracket on T5
6) Install pushrod on clevis pin
7) plumb hydraulic line
8) Bleed system (I still need to do this)
9) adjust accordingly (I still need to do this but I'm pretty close I'm guessing)
