Mk 4 Turn signal problem
Good day
Im building a Mk 4 kit with the RF wiring harness, LED rectangular tail lights, Russ Thompson turn signal stalk and the Hopkins converter. The turn indicator lights , brake lights and hazard flashers all work correctly when the running lights are on but when they are off, the turn indicators all flash together no matter if the left or right turn indicators are selected. The indicators flash brightly on the side that is selected and the other side flashes less brightly. Can anyone suggest where im going wrong?
